* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, include/bsp.h, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, startup/bspstart.c: Create bsp_get_work_area() into its
own file and use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* console/console.c, timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* clock/clock.c, include/bsp.h, startup/bspstart.c: Eliminate copies of
the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* console/console.c, include/bsp.h, startup/bspstart.c: Move
interrupt_stack_size field from CPU Table to Configuration Table.
Eliminate CPU Table from all ports. Delete references to CPU Table in
all forms.
* console/console.c, startup/bspstart.c: Moved most of the remaining
CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
PR 1257/bsps
* startup/bspclean.c: Code outside of cpukit should use the public API
for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* bsp_specs: Remove qrtems_debug.
Remove *cpp:.
* include/coverhd.h: Correct license URL and/or fix mistake in
copyright notice. Both of these mistakes appear to be from code
submitted after these changes were made previously.
* Makefile.am: Use preinstall.am.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* .cvsignore: New file.
* clock/clock.c: New file.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
nios2_iss/ChangeLog, nios2_iss/Makefile.am, nios2_iss/bsp_specs,
nios2_iss/configure.ac, nios2_iss/nios2_iss.ptf,
nios2_iss/nios2_iss.sh, nios2_iss/times, nios2_iss/console/console.c,
nios2_iss/include/bsp.h, nios2_iss/include/bspopts.h.in,
nios2_iss/include/coverhd.h, nios2_iss/include/tm27.h,
nios2_iss/shmsupp/addrconv.c, nios2_iss/shmsupp/getcfg.c,
nios2_iss/shmsupp/lock.c, nios2_iss/shmsupp/mpisr.c,
nios2_iss/start/crtnn.s, nios2_iss/start/start.S,
nios2_iss/startup/bspclean.c, nios2_iss/startup/bspstart.c,
nios2_iss/startup/linkcmds, nios2_iss/startup/main.c,
nios2_iss/startup/setvec.c, nios2_iss/timer/timer.c: New files.
