path: root/c/src/lib/libbsp/nios2/nios2_iss (follow)
* Use $(EXEEXT) [defaults to "exe"] to generate binariesNick Withers2013-08-091-1/+1
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-278/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber2012-11-151-0/+1
| | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
* Revert "Add bspopts.h.in."Gedare Bloom2012-08-061-31/+0
| | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Add bspopts.h.in.Ralf Corsépius2012-05-241-0/+31
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1112-27/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-072-0/+6
* Remove CVS-Ids.Ralf Corsépius2012-05-042-6/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-012-12/+0
* 2011-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-213-6/+8
| | | | | * console/console.c (ISS_output_char): Add return type. * timer/timer.c: Remove unused vars "old_ie".
* 2011-09-01 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-012-7/+14
| | | | * startup/bspstart.c: Update due to API changes.
* 2011-07-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-07-292-6/+4
| | | | * bsp_specs: Remove *lib (Anachronism).
* 2011-03-21 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-03-216-240/+6
| | | | | | * Makefile.am: Remove stub version. * shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-1/+6
| | | | | * shmsupp/lock.c: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-092-1/+7
| | | | | * timer/timer.c: Include <rtems/btimer.h>. Fix benchmark_timer_read() definition.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-022-2/+6
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* Whitespace removal.Ralf Corsepius2009-11-302-6/+6
* Whitespace removal.Ralf Corsepius2009-11-281-1/+1
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-212-3/+4
| | | | * make/custom/nios2_iss.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+34
| | | | * make/custom/nios2_iss.cfg: New (relocated from /make/custom).
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-152-2/+5
| | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-162-10/+8
| | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
* 2009-04-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-04-062-2/+10
| | | | * startup/linkcmds: Move stack so it does not overlap workarea.
* 2009-03-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-03-264-1/+12
| | | | | | * Makefile.am, console/console.c, startup/linkcmds: Now links but clearly the starting stack overlaps regular memory and needs to be moved.
* 2009-03-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-03-033-150/+25
| | | | * Makefile.am, console/console.c: Use shared polled console framework.
* 2009-03-02 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-03-035-3/+22
| | | | | * Makefile.am, preinstall.am, include/bsp.h, startup/setvec.c: Now compiles again but applications do not link.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-042-2/+8
| | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19.
* 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-10-024-34/+7
| | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed.
* 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-10-024-107/+7
| | | | | * Makefile.am, preinstall.am: Use shared stub coverhd.h * include/coverhd.h: Removed.
* 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-302-7/+10
| | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules.
* 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-303-2/+7
| | | | | * clock/clock.c: include "../../../shared/clockdrv_shell.h". * Makefile.am: Reflect changes above.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-8/+15
| | | | * Makefile.am: Eliminate *_SOURCES.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-1/+7
| | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-292-2/+4
| | | | * Makefile.am: Remove noinst_PROGRAMS (Unused).
* 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-242-1/+4
| | | | * Makefile.am: Cosmetics.
* 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-232-1/+7
| | | | | | * configure.ac: Make letting boot_card() handle work area allocation mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-234-33/+19
| | | | | | * Makefile.am, configure.ac: BSP specific bsp_cleanup() is a dupe of a shared one. * startup/bspclean.c: Removed.
* 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-182-14/+4
| | | | * include/bsp.h: Remove unnecessary boilerplate comments.
* 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-165-45/+11
| | | | | | * Makefile.am, include/bsp.h, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. * startup/bspgetworkarea.c: Removed.
* 2008-09-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-144-62/+48
| | | | | | * Makefile.am, startup/bspstart.c: Create bsp_get_work_area() into its own file and use BSP Framework to perform more initialization. * startup/bspgetworkarea.c: New file.
* 2008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-102-2/+6
| | | | | | * include/bsp.h: Review of all bsp_cleanup() implementations. In this phase, all prototypes were removed from bsp.h and empty implementations were removed and made to use the shared stub.
* Convert to "bool".Ralf Corsepius2008-09-052-7/+5
* 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-051-0/+4
| | | | * console/console.c, timer/timer.c: Convert to "bool".
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-312-19/+14
| | | | | * timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-312-10/+15
| | | | | * timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions.
* Cleanup.Ralf Corsepius2008-07-141-6/+0
* 2008-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-05-152-26/+14
| | | | | | | | | | | | | | * startup/bspstart.c: Add capability for bootcard.c BSP Initialization Framework to ask the BSP where it has memory for the RTEMS Workspace and C Program Heap. These collectively are referred to as work area. If the BSP supports this, then it does not have to include code to split the available memory between the two areas. This reduces the amount of code in the BSP specific bspstart.c file. Additionally, the shared framework can initialize the C Library, call rtems_debug_enable(), and dirty the work area memory. Until most/all BSPs support this new capability, if the BSP supports this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When the transition is complete, this autoconf macro can be removed.
