* | build-system: Parallel build all subdirs. | Chris Johns | 2017-05-24 | 1 | -1/+1 |
* | moxiesim/bsp_specs: Add crtbegin/end to fix link issues | Joel Sherrill | 2016-11-03 | 1 | -2/+2 |
* | moxie/moxiesim/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | moxie/moxiesim: Remove include of <rtems/console.h> from <bsp.h> and fix ↵ | Joel Sherrill | 2016-03-29 | 1 | -1/+0 |
| | | | | warnings | ||||
* | moxie/moxiesim/include/bsp.h: Do not include <rtems/clockdrv.h> | Joel Sherrill | 2016-03-27 | 1 | -1/+0 |
* | Use linker set for libio initialization | Sebastian Huber | 2016-02-03 | 1 | -2/+2 |
| | | | | Update #2408. | ||||
* | score: Introduce Thread_Entry_information | Sebastian Huber | 2016-01-11 | 1 | -1/+1 |
| | | | | | | | This avoids potential dead code in _Thread_Handler(). It gets rid of the dangerous function pointer casts. Update #2514. | ||||
* | bsps: Delete superfluous bsp_pretasking_hook() | Sebastian Huber | 2015-12-10 | 1 | -1/+1 |
| | | | | | | Use the bsp_predriver_hook() instead. Update #2408. | ||||
* | Add RTEMS linker sets | Sebastian Huber | 2015-12-08 | 1 | -1/+2 |
* | moxiesim/configure.ac: Fix typo | Joel Sherrill | 2015-10-20 | 1 | -1/+1 |
| | | | | updates 2254. | ||||
* | Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guard | Joel Sherrill | 2015-07-16 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done | ||||
* | moxie machine type not supported by rtems-syms. See #2213 | Joel Sherrill | 2015-03-24 | 1 | -0/+1 |
| | | | | updates #2313. | ||||
* | moxiesim: Add conditional logic to handle old and new gas syntax | Anthony Green | 2015-01-10 | 2 | -2/+21 |
* | bsp/moxiesim: Add cache manager implementation | Sebastian Huber | 2014-12-17 | 1 | -0/+5 |
| | | | | Close #2220. | ||||
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 2 | -2/+2 |
* | bsps: Move extern "C" to not cover includes | Sebastian Huber | 2014-10-23 | 1 | -4/+4 |
| | | | | Some includes may use C++ and this conflicts if surrounded extern "C". | ||||
* | moxie/moxiesim/include/bsp.h: Add include of <bsp/default-initial-extension.h> | Joel Sherrill | 2014-10-19 | 1 | -4/+6 |
* | moxie/moxiesim: Remove __main() | Joel Sherrill | 2014-10-19 | 2 | -22/+1 |
| | | | | Moxie has .init section and that is what handles the constructors. | ||||
* | moxie/moxiesim: Remove unused method MOXIEBD_Install_IRQ | Joel Sherrill | 2014-10-19 | 2 | -22/+1 |
* | Add console-polled.h and update all BSPs that should use it. | Joel Sherrill | 2014-10-10 | 3 | -2/+10 |
| | | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static. | ||||
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 1 | -6/+6 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | bsps: Do not build tests that require a tick interrupt. | Chris Johns | 2014-05-28 | 1 | -0/+5 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following BSPs do not have tick support so the tests fail: arm1136jfs arm1136js arm7tdmi arm920 armcortexa9 (does not run any more) avrtest h8sim h8sxsim m32csim m32rsim moxiesim simsh1 simsh2 simsh4 v850e1sim v850e2sim v850e2v3sim v850esim v850essim v850sim This list was provided by Joel in the following post: http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html | ||||
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 1 | -1/+3 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | moxiesim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -9/+0 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 3 | -3/+3 |
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 1 | -0/+14 |
* | Add sample Moxie BSP for GDB sim | Anthony Green | 2013-02-28 | 15 | -0/+646 |
Signed-off-by: Anthony Green <green@moxielogic.com> |
