path: root/c/src/lib/libbsp/moxie/moxiesim (follow)
* moxiesim/configure.ac: Fix typoJoel Sherrill2015-10-201-1/+1
* Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guardJoel Sherrill2015-07-161-2/+2
| | | | | | | | | | | | | | | | | This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done
* moxie machine type not supported by rtems-syms. See #2213Joel Sherrill2015-03-241-0/+1
| | | | updates #2313.
* moxiesim: Add conditional logic to handle old and new gas syntaxAnthony Green2015-01-102-2/+21
* bsp/moxiesim: Add cache manager implementationSebastian Huber2014-12-171-0/+5
| | | | Close #2220.
* Update bug report URLSebastian Huber2014-12-051-1/+1
* bsps: Move extern "C" to not cover includesSebastian Huber2014-10-231-4/+4
| | | | Some includes may use C++ and this conflicts if surrounded extern "C".
* moxie/moxiesim/include/bsp.h: Add include of <bsp/default-initial-extension.h>Joel Sherrill2014-10-191-4/+6
* moxie/moxiesim: Remove __main()Joel Sherrill2014-10-192-22/+1
| | | | Moxie has .init section and that is what handles the constructors.
* moxie/moxiesim: Remove unused method MOXIEBD_Install_IRQJoel Sherrill2014-10-192-22/+1
* Add console-polled.h and update all BSPs that should use it.Joel Sherrill2014-10-103-2/+10
| | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static.
* Regenerate all preinstall.am files.Joel Sherrill2014-08-281-6/+6
| | | | | Apparently, at some point automake output changed and these were not updated.
* bsps: Do not build tests that require a tick interrupt.Chris Johns2014-05-281-0/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following BSPs do not have tick support so the tests fail: arm1136jfs arm1136js arm7tdmi arm920 armcortexa9 (does not run any more) avrtest h8sim h8sxsim m32csim m32rsim moxiesim simsh1 simsh2 simsh4 v850e1sim v850e2sim v850e2v3sim v850esim v850essim v850sim This list was provided by Joel in the following post: http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
* bsps: Fix TLS support in linker command filesSebastian Huber2014-04-221-1/+3
| | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section.
* moxiesim/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-9/+0
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-213-3/+3
* bsps: Thread-local storage (TLS) for linkcmdsSebastian Huber2014-02-041-0/+14
* Add sample Moxie BSP for GDB simAnthony Green2013-02-2812-0/+604
Signed-off-by: Anthony Green <green@moxielogic.com>
