+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* Makefile.am: Change to one file per line. Clean up.
* ChangeLog, Makefile.am: Add bsp_reset() stub.
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
for libchip serial drivers.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* include/tm27.h:
* startup/bspstart.c, timer/timer.c:
* timer/timer.c: Include <rtems/btimer.h>.
* csb350/clock/clockdrv.c, csb350/network/network.c,
csb350/start/start.S, csb350/timer/timer.c,
genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c,
jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where
license said found in found in.
* startup/bspstart.c: Add include to fix warning.
PR 1599/cpukit
* shared/irq/exception.S: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
* shared/irq/exception.S: Removed _ISR_Signals_to_thread_executing
declaration.
PR 1573/cpukit
* shared/irq/exception.S: Add a per cpu data structure which contains
the information required by RTEMS for each CPU core. This
encapsulates information such as thread executing, heir, idle and
dispatch needed.
* Makefile.am, preinstall.am: Fix typo.
* shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h,
shared/startup/idtmem.S, shared/startup/idttlb.S: New files.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S:
Removed.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
* startup/usc.S: New file.
* shared/irq/exception.S: rbtx4925, rbtx4938, and hurricane had very
similar versions of exception. Now all use shared/irq/exception.S
* configure.ac: rbtx4925, rbtx4938, and hurricane had very similar
* Makefile.am, configure.ac: rbtx4925, rbtx4938, and hurricane had very
* startup/exception.S: Removed.
