* Makefile.am: install runtest to bsptools_bindir.
* liblnk/Makefile.am: Cosmetics.
* liblnk/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Fix preinstallation of include/coverhd.h.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* start/start.S: Comment out string after #endif.
* bsp_specs: Remove *lib:.
* console/console.c, include/bsp.h, include/coverhd.h,
startup/bspclean.c, startup/bspstart.c, startup/setvec.c: URL for
license changed.
* console/console-io.c, include/bsp.h, startup/bspclean.c,
startup/bspstart.c, timer/timer.c, tools/runtest: URL for license
changed.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c, startup/gdb-support.c, timer/timer.c: URL for
license changed.
liblnk/Makefile.am: Reflect having moved automake.
* runtest: Add fileio to list of interactive tests.
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -D__USE_INIT_FINI__.
Remove *.cpp (Now unused).
PR 433/tools
* mips-stub.c: Patch from C. M. Heard <heard@pobox.com> described as:
The purpose of the patch is to make the stub ignore all
characters except '+' (ack) or '-' (nak) when it has transmitted a
packet and expects an acknowledgment. Without the patch,
putpacket() will retransmit each time it receives anything other
than '+' when expecting an ack, and that, bitter experience has
found, frequently results in the stub failing to sync up when
initially attaching to gdb.
I think that rtems users will notice significant improvement in
the of the mips stub if this patch is incorporated in the
distribution; certainly I did in my stand-aline environment. I
should hasten to add that it is only an improvement and not a 100%
cure for synchronization problems because '+' characters can (and
do) during as message data, and it's still possible for these to
be mistaken as acks. I have no idea how to fix that short of
redesigning the gdb-remote protocol.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* bsp_specs: Added crtbegin/crtend and INIT_FINI for C++ support.
* linkcmds: Added .init, .fini & related sections.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* mips-stub.c: Removed warnings.
* startup/bspclean.c, startup/bspstart.c: Removed warnings.
* startup/gdb-support.c, startup/linkcmds: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* rtems-stub-glue.c: Removed should only be common copy.
* startup/linkcmds: Move .init section after text section so
C+ global constructors work.
* mips-stub.c: Re-debugged a breakpoint problem, zbreak target
address was a char * which caused the target instruction to not
be fully copied, so the zbreak logic corrupted the original
instruction and didn't insert a valid break instruction.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
