* mips64orion/.cvsignore, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/README,
mips64orion/acinclude.m4, mips64orion/configure.ac,
mips64orion/p4000/.cvsignore, mips64orion/p4000/ChangeLog,
mips64orion/p4000/Makefile.am, mips64orion/p4000/README,
mips64orion/p4000/bsp_specs, mips64orion/p4000/configure.ac,
mips64orion/p4000/times, mips64orion/p4000/console/.cvsignore,
mips64orion/p4000/console/Makefile.am,
mips64orion/p4000/console/console.c, mips64orion/p4000/console/led.S,
mips64orion/p4000/include/.cvsignore,
mips64orion/p4000/include/bsp.h, mips64orion/p4000/include/coverhd.h,
mips64orion/p4000/liblnk/.cvsignore,
mips64orion/p4000/liblnk/Makefile.am,
mips64orion/p4000/liblnk/lnklib.S,
mips64orion/p4000/start/.cvsignore,
mips64orion/p4000/start/Makefile.am, mips64orion/p4000/start/start.S,
mips64orion/p4000/startup/.cvsignore,
mips64orion/p4000/startup/Makefile.am,
mips64orion/p4000/startup/bspclean.c,
mips64orion/p4000/startup/bspstart.c,
mips64orion/p4000/startup/ghlinkcmds,
mips64orion/p4000/startup/idtmem.S,
mips64orion/p4000/startup/idttlb.S,
mips64orion/p4000/startup/inittlb.c,
mips64orion/p4000/startup/linkcmds,
mips64orion/p4000/startup/setvec.c,
mips64orion/p4000/wrapup/.cvsignore,
mips64orion/p4000/wrapup/Makefile.am: Removed.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* start/Makefile.am: Use project_lib_DATA.
* liblnk/Makefile.am: Cosmetics.
* liblnk/Makefile.am: Remove all-local: $(ARCH).
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* console/console.c, include/bsp.h, include/coverhd.h,
startup/bspclean.c, startup/bspstart.c, startup/setvec.c: URL for
license changed.
liblnk/Makefile.am: Reflect having moved automake.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* acinclude.m4: New file.
