* startup/linkcmds*: Add FreeBSD sysctl() sections.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* acinclude.m4: New file.
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
BSP needs to be eliminated.
dependencies of "Makefile".
--enable-maintainer-mode.
