* | removed reference to no_bsp. | Joel Sherrill | 1997-04-07 | 1 | -4/+10 | |
| | | | | added prototypes. | |||||
* | commented out sccs_id to eliminate warnings | Joel Sherrill | 1997-04-07 | 1 | -4/+10 | |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 6 | -0/+314 | |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 1 | -0/+34 | |
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 1 | -0/+1 | |
* | added $Id$ string to file header | Joel Sherrill | 1996-09-11 | 9 | -8/+25 | |
* | new files | Joel Sherrill | 1996-09-11 | 2 | -0/+406 | |
* | idtmem.S: changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 2 | -6/+4 | |
| | | | | | | iface.c: commented out routines now provided by rtems setvec.c: remov | |||||
* | changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 1 | -2/+2 | |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 13 | -0/+2232 | |
Derrick Ostertag (ostertag@transition.com). |
