* | removed warning for implicit declaration of idtsim__exit() | Joel Sherrill | 1998-05-02 | 1 | -0/+2 |
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 1 | -0/+1 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -3/+7 |
| | | | | main.c: added return statement to eliminate a warning. | ||||
* | added $Id$ string to file header | Joel Sherrill | 1996-09-11 | 1 | -1/+2 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 1 | -0/+30 |
Derrick Ostertag (ostertag@transition.com). |
