* start/Makefile.am: Use project_lib_DATA.
* liblnk/Makefile.am: Remove all-local: $(ARCH).
liblnk/Makefile.am: Reflect having moved automake.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
Derrick Ostertag (ostertag@transition.com).
