* mips-stub.c: Debugged & tweaked the gdb command processing,
zbreak stuff, breakpoint and step code. Implemented 'T' command
support and debugged remote gdb support w/ the Mongoose bsp.
Added the memory segment support.
* memlimits.h: Disabled all contents in favor of memory sement
support. This file could probably go away.
* rtems-stub-glue.c (rtems_gdb_index_to_stub_id()): New routine.
rtems_gdb_stub_get_register_from_context(): Implemented MIPS version.
rtems_gdb_stub_get_offsets(): Implemented MIPS version.
* README: Updated.
* Makefile, stubinit.S, r46kstub.ld, ioaddr.h: Removed as unused
with RTEMS.
* r46kstub.c: Renamed to mips-stub.c.
* mips-stub.c: New file -- was r46kstub.c.
* memlimits.h: New file was limits.h.
* limits.h: Removed.
* r4600.h: Eliminated need for this file.
* README: Updated.
* gdb_if.h: Added CVS Id.
* mips-stub.c: Attempt to deal with MIPS1 versus MIPS3.
* Merged r46kstub.c into RTEMS distribution without modification.
I got the code from Franz Fischer <Franz.Fischer@franz-fischer.de>
who had used this with an old version of RTEMS with the mips64orion
port of RTEMS. After adding this to the repository, I will tailor
this to work with the RTEMS exception processing model and trim
no longer needed parts.
* ChangeLog, gdb_if.h, ioaddr.h, limits.h, Makefile, mips_opcode.h,
r4600.h, r46kstub.c, r46kstub.ld, README, stubinit.S:
