Update #4267.
Update #3375.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3250.
header file.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
Avoid duplicate mips_vector_isr_handlers() declarations.
Update #2408.
The size of the sample executables without this option were:
105928 7448 12304 125680 1eaf0 base_sp.exe
114276 6464 11904 132644 20624 hello.exe
64908 4248 8592 77748 12fb4 minimum.exe
568808 80292 24680 673780 a47f4 fileio.exe
128232 9936 12472 150640 24c70 nsecs.exe
162840 20132 12976 195948 2fd6c paranoia.exe
109944 8300 12352 130596 1fe24 ticker.exe
109880 7676 15728 133284 208a4 unlimited.exe
1035584 48120 19681 1103385 10d619 cxx_iostream.exe
216136 18520 12609 247265 3c5e1 cdtest.exe
205784 22188 14180 242152 3b1e8 capture.exe
The size of the sample executables with this option enabled were:
93464 6776 12188 112428 1b72c base_sp.exe
99480 5780 11788 117048 1c938 hello.exe
40616 3208 8512 52336 cc70 minimum.exe
545448 77224 24130 646802 9de92 fileio.exe
117528 9224 12340 139092 21f54 nsecs.exe
149784 19428 12804 182016 2c700 paranoia.exe
98760 7616 12204 118580 1cf34 ticker.exe
95672 6976 15620 118268 1cdfc unlimited.exe
530280 38896 18753 587929 8f899 cxx_iostream.exe
198832 16492 12473 227797 379d5 cdtest.exe
190632 21160 14036 225828 37224 capture.exe
Update #2408.
Update #2408.
