not updated.
The MIPS port defines CPU_SIMPLE_VECTORED_INTERRUPTS to FALSE.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
for details.
* Makefile.am: Change to one file per line. Clean up.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* Makefile.am: rbtx4925 and rbtx4938 had copies of the same file with
only minor differences. Both now use shared/irq/exception.S
* startup/exception.S: Removed.
* startup/linkcmds: Revert previous change. Remove .reginfo from .bss
section where it was present.
* startup/linkcmds: Add NOLOAD to .bss to eliminate warnings.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* make/custom/rbtx4938.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/rbtx4938.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* startup/exception.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* liblnk/regs.S: Remove (Rename into liblnk.h).
* liblnk/regs.h: New (Renamed from liblnk/regs.S).
* Makefile.am, liblnk/pmon.S: Reflect renamer.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
