* Makefile.am: Change to one file per line. Clean up.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Many files were duplicated across MIPS
BSPs. Now those which were directly copied are shared.
* liblnk/lnklib.S, liblnk/pmon.S, liblnk/regs.h, startup/idtmem.S,
startup/idttlb.S: Removed.
* Makefile.am: rbtx4925 and rbtx4938 had copies of the same file with
only minor differences. Both now use shared/irq/exception.S
* startup/exception.S: Removed.
* startup/linkcmds: Revert previous change. Remove .reginfo from .bss
section where it was present.
* startup/linkcmds: Add NOLOAD to .bss to eliminate warnings.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* make/custom/rbtx4938.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/rbtx4938.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* startup/exception.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* liblnk/regs.S: Remove (Rename into liblnk.h).
* liblnk/regs.h: New (Renamed from liblnk/regs.S).
* Makefile.am, liblnk/pmon.S: Reflect renamer.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspstart.c: Create
bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* console/console-io.c: Convert to "bool".
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* startup/bspstart.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* bsp_specs: Remove qrtems_debug.
* bsp_specs: Remove --oformat=...
Use old_link for -qrtems (Prevents *.link from killing endianness).
* bsp_specs: Remove lib (Now expected to exist in GCC).
* console/console-io.c, startup/exception.S: Correct license URL and/or
fix mistake in copyright notice. Both of these mistakes appear to be
from code submitted after these changes were made previously.
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
