* | bsps: Simplify RTEMS_BSP_CLEANUP_OPTIONS | Sebastian Huber | 2017-11-22 | 1 | -1/+1 |
| | | | | | | | | | Remove BSP-specific defaults for RTEMS_BSP_CLEANUP_OPTIONS to simplify the BSP configuration and documentation. Change defaults to: BSP_PRESS_KEY_FOR_RESET=0 BSP_RESET_BOARD_AT_EXIT=1 BSP_PRINT_EXCEPTION_CONTEXT=1 | ||||
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 1 | -2/+0 |
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 1 | -1/+1 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 1 | -1/+0 |
| | | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS. | ||||
* | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-16 | 1 | -1/+2 |
| | | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options. | ||||
* | 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-23 | 1 | -1/+1 |
| | | | | | | * configure.ac: Make letting boot_card() handle work area allocation mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS. | ||||
* | 2008-09-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-14 | 1 | -0/+2 |
| | | | | | | | * Makefile.am, configure.ac, startup/bspstart.c: Create bsp_get_work_area() into its own file and use BSP Framework to perform more initialization. * startup/bspgetworkarea.c: New file. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -1/+1 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -2/+2 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 1 | -0/+21 |
