Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, startup/bspstart.c: Create
bsp_get_work_area() into its own file and use BSP Framework to
perform more initialization.
* startup/bspgetworkarea.c: New file.
* configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING.
Remove AM_CONDITIONAL(HAS_MP).
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
* configure.in: Remove.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, add
bspopts.h.
* include/.cvsignore: Add bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of H_FILES.
* Shared memory support removed since it was non-functional.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am: Modified to
reflect above.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that contains:
* Removes MKLIB
handling)
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
that converts the no_cpu directory to automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
