Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3250.
Updates #3250.
header file.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
Avoid duplicate mips_vector_isr_handlers() declarations.
Update #2408.
The size of the sample executables without this option were:
105752 7448 12288 125488 1ea30 base_sp.exe
114212 6464 11904 132580 205e4 hello.exe
64844 4248 8592 77684 12f74 minimum.exe
568632 80292 24664 673588 a4734 fileio.exe
128056 9936 12456 150448 24bb0 nsecs.exe
162664 20132 12960 195756 2fcac paranoia.exe
109768 8300 12336 130404 1fd64 ticker.exe
109816 7676 15728 133220 20864 unlimited.exe
1035520 48120 19681 1103321 10d5d9 cxx_iostream.exe
215960 18520 12593 247073 3c521 cdtest.exe
205608 22188 14164 241960 3b128 capture.exe
The size of the sample executables with this option enabled were:
93688 6776 12216 112680 1b828 base_sp.exe
99720 5780 11804 117304 1ca38 hello.exe
40888 3208 8496 52592 cd70 minimum.exe
545656 77224 24110 646990 9df4e fileio.exe
117752 9224 12304 139280 22010 nsecs.exe
149992 19428 12848 182268 2c7fc paranoia.exe
98968 7616 12184 118768 1cff0 ticker.exe
95912 6976 15636 118524 1cefc unlimited.exe
530504 38896 18721 588121 8f959 cxx_iostream.exe
199040 16492 12517 228049 37ad1 cdtest.exe
190856 21160 14000 226016 372e0 capture.exe
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
These BSPs are little endian while most are big endian.
The dl tool does not support the -EL option yet.
updates 2279.
