* startup/Makefile.am: Add bsplib_DATA = linkcmds ghlinkcmds.
* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* start/start.S: Invoke boot_card() not main().
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* console/console.c: Added printk() support.
* start/start.S: init_exc_vecs is now called mips_install_isr_entries.
* wrapup/Makefile.am: Corrected to reflect new libcpu structure.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* console/led.S: Switch from using <idtmon.h> to <asm.h>.
* console/start.S: Switch from using <idtmon.h> to <asm.h>. Added
define of PMON stacksize.
* console/idtmem.S: Switch from using <idtmon.h> to <asm.h>. Also
reworked conditionals to use gcc predefines.
* console/idttlb.S: Ditto.
* console/Makefile.am, liblnk/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
that contains:
* Removes MKLIB
handling)
converted to automake.
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
BSP needs to be eliminated.
<ian@airs.com>:
The pc386 linker scripts omits .gnu.linkonce.r* sections. It's not a
big deal, but they should be treated like .rodata sections. ELF
versions of g++ generate them for static constants defined in template
classes, such as string::npos.
by newlib.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
"gmake debug".
enclose.
interpreted at the right point per Eric Norum's discovery:
The problem with the my previous `fix' for adding linker commands
was with the ordering of the options to the linker.
For example, to make a larger heap size, the application Makefile would
CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000
The command passed to the linker would be :
m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 .....
This doesn't work because the script in linkcmds inserts a default
value for HeapSize if HeapSize is not defined by the time the linker
looks at the linkcmds script.
The solution seems to be to move the -T linkcmds%s in the bsp_specs
file out of the link specfication and into the lib specification -- a
little unorthodox, perhaps, but it seems to work!
