* liblnk/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
converted to automake.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
added prototypes.
Derrick Ostertag (ostertag@transition.com).
