2018-04-23 | bsps: Move PCI drivers to bsps | Sebastian Huber | 1 | -1102/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2017-03-09 | libbsp/malta/pci/pci.c: Correct printk() formats | Joel Sherrill | 1 | -6/+6 | |
2016-03-10 | mips/malta: Use shared pci_find_device() and removed unused pci_list_devices() | Joel Sherrill | 2 | -379/+0 | |
Also includes .h file cleanup. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 3 | -3/+3 | |
2012-05-16 | pci.h cleanup - Consolidate common defines to cpukit pci.h | Joel Sherrill | 3 | -12/+4 | |
+ libbsp/sparc/shared/include/pci.h was largely a copy of an older version of the cpukit pci.h. Removed much of the contents and included <rtems/pci.h>. + sparc/*/pci*.c - Move to <rtems/pci.h> required updating to use uint32_t for dword accesses. + Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION + Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove PCI_MULTI_FUNCTION definitions in C files. + Move PCI_INVALID_VENDORDEVICEID definitions from various C files to cpukit pci.h | |||||
2012-04-04 | Add MIPS/Malta BSP. | Jennifer Averett | 3 | -0/+1489 | |
