Update #2408.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3250.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
Avoid duplicate mips_vector_isr_handlers() declarations.
Update #2408.
The size of the sample executables without this option were:
128028 1812 12224 142064 22af0 ticker.exe
52600 1324 8192 62116 f2a4 minimum.exe
1156240 2168 19696 1178104 11f9f8 cxx_iostream.exe
706952 5908 24600 737460 b40b4 fileio.exe
243232 2372 14084 259688 3f668 capture.exe
155660 1940 12376 169976 297f8 nsecs.exe
201256 2212 12896 216364 34d2c paranoia.exe
253696 1872 12576 268144 41770 cdtest.exe
124452 1812 12208 138472 21ce8 base_sp.exe
127640 1844 15648 145132 236ec unlimited.exe
133452 1780 11760 146992 23e30 hello.exe
The size of the sample executables with this option enabled were:
115052 1712 12096 128860 1f75c ticker.exe
40760 1256 8144 50160 c3f0 minimum.exe
671768 2076 18688 692532 a9134 cxx_iostream.exe
679672 5696 23992 709360 ad2f0 fileio.exe
227384 2196 13924 243504 3b730 capture.exe
143132 1832 12248 157212 2661c nsecs.exe
187736 2104 12768 202608 31770 paranoia.exe
234324 1788 12448 248560 3caf0 cdtest.exe
111556 1712 12080 125348 1e9a4 base_sp.exe
112876 1744 15520 130140 1fc5c unlimited.exe
118120 1688 11696 131504 201b0 hello.exe
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
closes 2253
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
output.
The MIPS port defines CPU_SIMPLE_VECTORED_INTERRUPTS to FALSE.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
