* Makefile.am: Change to one file per line. Clean up.
* ChangeLog, Makefile.am: Add bsp_reset() stub.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* include/tm27.h:
* timer/timer.c: Include <rtems/btimer.h>.
* csb350/clock/clockdrv.c, csb350/network/network.c,
csb350/start/start.S, csb350/timer/timer.c,
genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c,
jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where
license said found in found in.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
* start/start.S, startup/linkcmds: Revert previous change. Remove
.reginfo from .bss section where it was present.
* startup/linkcmds: Add NOLOAD to .bss to eliminate warnings.
* clock/clockdrv.c: Split hardware initialization code into
Clock_driver_support_initialize_hardware().
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* make/custom/jmr3904.cfg: Remove RTEMS_BSP_FAMILY.
* startup/bspstart.c: Fix warnings.
* make/custom/jmr3904.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* configure.ac: Make runtest an autoconf generated file so we can
insert target alias. Also detect more program termination conditions
so tests are killed more reliably.
* runtest.in: New file.
* runtest: Removed.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/regs.S: Remove (Renamed into start/regs.h).
* start/regs.h: New (Renamed from start/regs.S).
* Makefile.am, start/start.S: Reflect renamer.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am: bsp_cleanup() had the same code which was executed when
you returned from boot_card() to start.S. So just use the stub
bsp_cleanup() implementation and remove a file.
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* timer/timer.c: Add missing prototypes.
* runtest: Attempt to prevent runaways.
* runtest: Major update. Now more likely not to run away.
* runtest: Strip .exe or .ralf from file names.
added support for an optional separate heap area.
* configure.ac, startup/bspstart.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
