* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -4/+4 |
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-04 | 1 | -1/+1 |
| | | | | | * wrapup/Makefile.am: Eliminate TMPINSTALL_FILES. Remove $(OBJS) from all-local. | ||||
| | | | | * wrapup/Makefile.am: Add $(LIB) to all-local. | ||||
* | 2002-06-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-30 | 1 | -6/+0 |
| | | | | * wrapup/Makefile.am: Remove preinstallation of libbsp.a, | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2000-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-13 | 1 | -0/+2 |
| | | | | | | | | | | | | * README: Updated. We are now vectoring a clock tick ISR handler. But RTEMS is not returning from the ISR properly. * clock/clockdrv.c: Now causes interrupts but has not been calibrated. * include/bsp.h: Use <libcpu/tx3904.h> * startup/Makefile.am: Add setvec.c from shared. * startup/bspstart.c: Initialize the status register (SR) so no interrupts are masked but global interrupts (SR_IEC) are off. Added call to install the ISR prologue code. * wrapup/Makefile.am: Pick up more pieces from libcpu. | ||||
* | 2000-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-25 | 2 | -0/+36 |
* The JMR BSP is for a Toshiba TX39 evaluation board but can also be used with the mips simulator in gdb. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
