The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* Makefile.am: Remove times from EXTRA_DIST (Non-existant).
* startup/Makefile.am: Remove exit.c, setvec.c from EXTRA_DIST.
* console/Makefile.am: Remove console.c from EXTRA_DIST.
* wrapup/Makefile.am: Reflect changes to libcpu.
* console/console-io.c, include/bsp.h, startup/bspclean.c,
startup/bspstart.c, timer/timer.c, tools/runtest: URL for license
changed.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Removed unused variable initialized.
* clock/Makefile.am: Fixed reference to ckinit.c.
* clock/clockdrv.c: Enabled fast idle.
* console/console-io.c: Added console_initialize_hardware().
* Makefile.am: Added tools subdirectory and removed commented out line.
* configure.in: Added tools subdirectory.
* tools: New subdirectory.
* tools/.cvsignore, tools/Makefile.am, tools/configure.in,
tools/runtest: New files -- based on powerpc/psim.
* clock/clockdrv.c: Guessed new value for clock tick. Need to
add fast idle support.
* include/bsp.h: tm27 support initiated.
* start/start.S: Fixed frame/endframe problems on _sys_exit.
* startup/bspstart.c: Increased Workspace size to 4 MBYTES!
* linkcmds: Increased Workspace size to 4 MBYTES!
* Most tests appear to run correctly!
* README: Updated to reflect current status. Misaligned reference
during initialization may be compiler problem.
* console/console-io.c: Added support for printk().
* startup/linkcmds: Reserve 512K for RTEMS Workspace.
* The JMR BSP is for a Toshiba TX39 evaluation board but
can also be used with the mips simulator in gdb.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, include/.cvsignore,
include/Makefile.am, include/bsp.h, start/.cvsignore,
start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
