2018-04-26 | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 1 | -30/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -4/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2000-12-13 | 2000-12-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+10 | |
* README: Updated. We are now vectoring a clock tick ISR handler. But RTEMS is not returning from the ISR properly. * clock/clockdrv.c: Now causes interrupts but has not been calibrated. * include/bsp.h: Use <libcpu/tx3904.h> * startup/Makefile.am: Add setvec.c from shared. * startup/bspstart.c: Initialize the status register (SR) so no interrupts are masked but global interrupts (SR_IEC) are off. Added call to install the ISR prologue code. * wrapup/Makefile.am: Pick up more pieces from libcpu. | |||||
2000-12-06 | 2000-12-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -16/+10 | |
* README: Updated to reflect status. * startup/linkcmds: Added .ctor and .dtor sections to no avail. | |||||
2000-11-30 | 2000-11-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -10/+18 | |
* README: Updated to reflect current status. Misaligned reference during initialization may be compiler problem. * console/console-io.c: Added support for printk(). * startup/linkcmds: Reserve 512K for RTEMS Workspace. | |||||
2000-11-25 | 2000-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+23 | |
* The JMR BSP is for a Toshiba TX39 evaluation board but can also be used with the mips simulator in gdb. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
