* start/start.S: Update for boot_card command line change.
* start/start.S: Fix name of idtsim__exit.
* start/start.S: bsp_cleanup() had the same code which was executed
when you returned from boot_card() to start.S. So just use the stub
bsp_cleanup() implementation and remove a file.
* startup/bspclean.c: Removed.
