line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
warnings
do
echo $b
# echo $g
-i $b
done
Conflicts:
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Eliminate tm27 items from bsp.h
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
* include/.cvsignore: New file.
