path: root/c/src/lib/libbsp/mips/genmongoosev (follow)
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-2/+7
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-05-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-245-6/+22
| | | | | | | * configure.in: Add bspopts.h. * include/bsp.h: Include bspopts.h. * include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES.
* 2001-05-24 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2001-05-243-15/+96
| | | | | | * Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>. * start/regs.S, start/start.S: Now works on Mongoose-V. Missed in previous patch.
* 2001-05-22 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2001-05-226-64/+142
| | | | | | | | | * Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>. * clock/clockdrv.c, console/conscfg.c: Corrected. * include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE. * startup/bspstart.c: Properly set initial status register and pending interrupts. * timer/timer.c: Works now.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-1/+5
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-05-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-072-2/+26
| | | | | * console/conscfg.c: Added an entry for the second serial port.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-202-1/+6
| | | | | * clock/clockdrv.c: Account for the fact that ClockRate is in cycles not megahertz.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-164-129/+30
| | | | | * start/start.S, startup/bspstart.c, startup/linkcmds: Cleanup that was not merged from the simple non-RTEMS program.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-162-5/+19
| | | | | | * start/start.S, startup/bspstart.c, startup/linkcmds: Modifications made with Gregory Menke <gregory.menke@gsfc.nasa.gov> as he debugged this BSP using a logic analyzer.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-163-81/+130
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-147-10/+22
| | | | | * clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S, startup/bspstart.c, timer/timer.c: Comments corrected.
* 2001-02-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-1428-0/+1400
* The Generic Mongoose-V BSP uses only the peripherals found on the Synova Mongoose-V CPU. This is a radiation hardened CPU based on the LSI Logic 33K. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/conscfg.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New files.
