for details.
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
for libchip serial drivers.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* timer/timer.c: Include <rtems/btimer.h>.
* csb350/clock/clockdrv.c, csb350/network/network.c,
csb350/start/start.S, csb350/timer/timer.c,
genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c,
jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where
license said found in found in.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* startup/linkcmds: Needed to be assigned to a memory region.
* startup/linkcmds: Revert previous change. Remove .reginfo from .bss
section where it was present.
* startup/linkcmds: Add NOLOAD to .bss to eliminate warnings.
* console/conscfg.c: Include <unistd.h>.
promCopyIcacheFlush.
* include/bsp.h: Add prototypes of promCopyDcacheFlush and
* startup/bspstart.c: Remove nested externs.
#include <libcpu/isr_entries.h.
* make/custom/genmongoosev.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/genmongoosev.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/regs.S: Remove (Renamed into start/regs.h).
* start/regs.h: New (Renamed from start/regs.S).
* Makefile.am, start/start.S: Reflect renamer.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspgetworkarea.c: Removed.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Split out bsp_get_work_area() into its own file and user BSP
Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* startup/bspstart.c: Add missing prototypes.
* timer/timer.c: Add missing prototypes.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
