* bsp_specs: Remove *lib:.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h,
startup/bspstart.c, startup/gdb-support.c, timer/timer.c: URL for
license changed.
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -D__USE_INIT_FINI__.
Remove *.cpp (Now unused).
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* bsp_specs: Added crtbegin/crtend and INIT_FINI for C++ support.
* linkcmds: Added .init, .fini & related sections.
* startup/gdb-support.c, startup/linkcmds: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus moving some of the
gdbstub support to a higher level.
* startup/Makefile.am: Modified to reflect above.
* start/start.S, startup/bspstart.c: Removed warnings.
* startup/gdb-support.c: Added calls into the mips-support gdb stub
for configuring the memory regions. Any bsp that wants to use the
gdbstub will need to do something similar.
* startup/Makefile.am: Added shared/gdbstub directory to include path.
* start/start.S: Added kseg1 test to enable cache flush code
* bsp_specs: Added -qnostartfile to disable including bsp's start.o
* startup/bspstart.c: Made clear_cache actually work, tweaked cpu
init to only turn on whats needed.
* startup/gdb-support.c: Added calls to uart 2 for gdb stub I/O and
a handy init function.
* startup/Makefile.am: Added rtems-stub-glue.c to C_FILES.
* startup/Makefile.am: Now compile the gdb stub.
* startup/bspstart.c: Fixed header block.
* startup/gdb-support.c: New file in stub state.
* include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h:
New files missed in previous commit.
* timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
* Update of BSP to address problems restarting, provide more
information during boot, and better handle ROM vs RAM images.
* README, include/bsp.h, start/regs.S, start/start.S,
startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* console/conscfg.c: Include rtems/bspIo.h instead of bspIo.h.
* timer/timer.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* start/regs.S, start/start.S: Now works on Mongoose-V. Missed
in previous patch.
* clock/clockdrv.c, console/conscfg.c: Corrected.
* include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE.
* startup/bspstart.c: Properly set initial status register and
pending interrupts.
* timer/timer.c: Works now.
