* | 2002-12-08 Greg Menke <gregory.menke@gsfc.nasa.gov> | Joel Sherrill | 2003-01-03 | 1 | -3/+6 |
| | | | | | * bsp_specs: Added crtbegin/crtend and INIT_FINI for C++ support. * linkcmds: Added .init, .fini & related sections. | ||||
* | 2002-08-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-21 | 1 | -4/+4 |
| | | | | * bsp_specs: Added support for -nostdlibs. | ||||
* | 2002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov> | Joel Sherrill | 2002-03-01 | 1 | -2/+2 |
| | | | | | | | | | * start/start.S: Added kseg1 test to enable cache flush code * bsp_specs: Added -qnostartfile to disable including bsp's start.o * startup/bspstart.c: Made clear_cache actually work, tweaked cpu init to only turn on whats needed. * startup/gdb-support.c: Added calls to uart 2 for gdb stub I/O and a handy init function. | ||||
* | 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 1 | -1/+1 |
| | | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g. | ||||
* | 2001-02-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-03-14 | 1 | -0/+23 |
* The Generic Mongoose-V BSP uses only the peripherals found on the Synova Mongoose-V CPU. This is a radiation hardened CPU based on the LSI Logic 33K. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/conscfg.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
