Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Update #2271.
* csb350/clock/clockdrv.c, csb350/network/network.c,
csb350/start/start.S, csb350/timer/timer.c,
genmongoosev/clock/clockdrv.c, genmongoosev/timer/timer.c,
jmr3904/timer/timer.c, jmr3904/tools/runtest.in: Fix typo where
license said found in found in.
* clock/clockdrv.c: Correct spelling error in comment.
* include/tm27.h: Delete duplicate #endif.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* clock/clockdrv.c, console/console-io.c, include/bsp.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, timer/timer.c: Correct license URL and/or fix
mistake in copyright notice. Both of these mistakes appear to be from
code submitted after these changes were made previously.
* clock/clockdrv.c: Add include of rtems/bspIo.h.
* include/tm27.h: Delete TX3904 code and leave stub.
* network/network.c: Eliminate warnings.
* startup/bspclean.c: Add include of rtems/bspIo.h. Reformat.
* acinclude.m4: Added csb350 to list of BSPs.
* csb350/Makefile.am, csb350/README, csb350/bsp_specs,
csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c,
csb350/console/console-io.c, csb350/include/bsp.h,
csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S,
csb350/start/start.S, csb350/startup/bspclean.c,
csb350/startup/bspstart.c, csb350/startup/linkcmds,
csb350/timer/timer.c: New BSP.
