Close #3250.
Close #4081.
Update #4267.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
maintain.
Update #3254.
Update #3239.
Update #2408.
Update #2408.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
The MIPS port defines CPU_SIMPLE_VECTORED_INTERRUPTS to FALSE.
for details.
* Makefile.am: Change to one file per line. Clean up.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Fix typo.
* Makefile.am, preinstall.am, start/start.S: Many files were duplicated
across MIPS BSPs. Now those which were directly copied are shared.
* start/regs.h: Removed.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/regs.S: Remove (Renamed into start/regs.h).
* start/regs.h: New (Renamed from start/regs.S).
* Makefile.am, start/start.S: Reflect renamer.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
