* | 2010-07-30 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-30 | 1 | -0/+6 |
| | | | | | | PR 1599/cpukit * shared/irq/exception.S: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary to more properly reflect the intent. | ||||
* | 2010-07-06 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-06 | 1 | -0/+5 |
| | | | | | * shared/irq/exception.S: Removed _ISR_Signals_to_thread_executing declaration. | ||||
* | 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 1 | -0/+8 |
| | | | | | | | | PR 1573/cpukit * shared/irq/exception.S: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. | ||||
* | 2010-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-13 | 1 | -0/+5 |
| | | | | | * shared/liblnk/lnklib.S, shared/liblnk/pmon.S, shared/liblnk/regs.h, shared/startup/idtmem.S, shared/startup/idttlb.S: New files. | ||||
| | | | | | * shared/irq/exception.S: rbtx4925, rbtx4938, and hurricane had very similar versions of exception. Now all use shared/irq/exception.S | ||||
* | 2010-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-05-13 | 1 | -0/+4 |
| | | | | * shared/irq/exception.S: New file. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 1 | -0/+4 |
| | | | | * shared/gdbstub/mips-stub.c: Remove warnings. | ||||
* | 2008-08-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-18 | 1 | -0/+4 |
| | | | | * shared/gdbstub/mips-stub.c: Add missing prototypes. | ||||
* | 2007-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-10 | 1 | -0/+5 |
| | | | | | * shared/gdbstub/mips-stub.c: Remove incorrect and unneccessary prototype of printk. | ||||
* | 2007-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-17 | 1 | -0/+4 |
| | | | | * jmr3904/tools/runtest: Do not run pppd.exe from batch mode script. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+4 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-14 | 1 | -0/+4 |
| | | | | * shared/gdbstub/mips-stub.c: Removed warnings. | ||||
* | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -1/+3 |
| | | | | | * configure.ac: AC_CONFIG_SRCDIR(csb350). * acinclude.m4: Regenerate. | ||||
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+1 |
| | | | | * README: Remove (obsolete). | ||||
* | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+4 |
| | | | | * acinclude.m4: Remove p4000. | ||||
* | 2005-02-24 Jay Monkman <jtm@lopingdog.com> | Jay Monkman | 2005-02-25 | 1 | -0/+11 |
| | | | | | | | | | | | * acinclude.m4: Added csb350 to list of BSPs. * csb350/Makefile.am, csb350/README, csb350/bsp_specs, csb350/configure.ac, csb350/times, csb350/clock/clockdrv.c, csb350/console/console-io.c, csb350/include/bsp.h, csb350/include/tm27.h, csb350/network/network.c, csb350/start/regs.S, csb350/start/start.S, csb350/startup/bspclean.c, csb350/startup/bspstart.c, csb350/startup/linkcmds, csb350/timer/timer.c: New BSP. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -0/+4 |
| | | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]). | ||||
* | 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-13 | 1 | -0/+5 |
| | | | | | * Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(RTEMS_BSP_FAMILY). | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-20 | 1 | -0/+5 |
| | | | | | * acinclude.m4: Reflect changes to bootstrap. * configure.ac: Remove RTEMS_CHECK_CUSTON_BSP. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -0/+4 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 1 | -0/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-10 | 1 | -0/+5 |
| | | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR. | ||||
* | 2000-11-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-27 | 1 | -0/+4 |
| | | | | * configure.in: Change mips64orion reference to mips. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -0/+5 |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 |
