PR414 - Fixed the global interupt vector register.
Linker command file to have the boot code in the first 8K.
The chip select remap needed to be volatile.
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* i2c/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* nvram/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* start/Makefile.am: Remove stray '\'.
Various fixes to get it compiling again.
* configure.ac: Remove RTEMS_ENV_RTEMS_BSP, add
AC_ARG_VAR(RTEMS_BSP)-hack instead.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, start/start.c: Removed warnings.
* console/console.c, start/start.c, startup/efi68k_wd.c:
* startup/m68k-stub.c: Removed typos.
* console/conscfg.c, startup/bspstart.c: Removed warnings.
* startup/m68k-stub.c: Removed warnings.
* network/network.c, startup/bspclean.c: Removed warnings.
* startup/page_table.c: Removed warnings.
