shmsupp/Makefile.am: Reflect having moved automake.
fatal/Makefile.am: Reflect having moved automake.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
spurious/Makefile.am: Reflect having moved automake.
i2c/Makefile.am: Reflect having moved automake.
nvram/Makefile.am: Reflect having moved automake.
* runtest: Add fileio to list of interactive tests.
* startup/Makefile.am: Remove USE_INIT_FINI.
PR414 - Fixed the global interupt vector register.
Linker command file to have the boot code in the first 8K.
The chip select remap needed to be volatile.
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* i2c/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* nvram/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* consolex/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/Makefile.am: Eliminate C_O_FILES.
* fatal/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* start/Makefile.am: Remove stray '\'.
Various fixes to get it compiling again.
* configure.ac: Remove RTEMS_ENV_RTEMS_BSP, add
AC_ARG_VAR(RTEMS_BSP)-hack instead.
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
