* | bsp/mrm332: Remove dead code | Sebastian Huber | 2017-09-14 | 1 | -2/+0 |
| | | | | Update #3132. | ||||
* | Simplify and unify BSP_output_char | Sebastian Huber | 2017-09-12 | 7 | -15/+0 |
| | | | | | | | | The BSP_output_char should output a char and not mingle with high level processing, e.g. '\n' to '\r\n' translation. Move this translation to rtems_putc(). Remove it from all the BSP_output_char implementations. Close #3122. | ||||
* | Include missing <rtems/bspIo.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
* | Optional Clock_driver_support_shutdown_hardware() | Sebastian Huber | 2017-08-04 | 3 | -12/+12 |
| | | | | | Make Clock_driver_support_shutdown_hardware() optional. This avoids the atexit() support on memory constrained targets. | ||||
* | bsps: Improve interrupt vector enable/disable API | Sebastian Huber | 2017-06-20 | 1 | -28/+16 |
| | | | | | | Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable() to not return a status code. Add bsp_interrupt_assert() and use it to validate the vector number in the vector enable/disable implementations. | ||||
* | build-system: Parallel build all subdirs. | Chris Johns | 2017-05-24 | 2 | -2/+2 |
* | genmcf548x/irq/irq.c: Fix incompatible pointer warning | Joel Sherrill | 2017-04-24 | 1 | -2/+8 |
* | mcf5235/console/console.c: Fix indentation and add braces | Joel Sherrill | 2017-04-24 | 1 | -5/+6 |
* | uC5282/startup/bspstart.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -6/+16 |
* | uC5282/console/console.c: Add braces and correct indentation to fix warnings | Joel Sherrill | 2017-04-24 | 1 | -5/+6 |
* | gen68340/startup/dumpanic.c: Fix printf() format warnings | Joel Sherrill | 2017-04-24 | 1 | -10/+10 |
* | m68k/mrm332/./sci.c: Use inttypes.h constants removes 6 warnings. | Cillian O'Donnell | 2017-04-14 | 1 | -6/+7 |
* | gen68340/startup/dumppanic.c: Fix warnings | Joel Sherrill | 2017-04-04 | 1 | -28/+28 |
* | mrm332-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf5225x-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | mcf52235-testsuite.tcfg: Add linpack | Joel Sherrill | 2017-04-04 | 1 | -0/+1 |
* | termios: Synchronize with latest FreeBSD headers | Kevin Kirspel | 2017-03-22 | 11 | -46/+44 |
| | | | | | | | | | | | Adding modified FreeBSD headers to synchronize RTEMS termios with FreeBSD. Modify termios to support dedicated input and output baud for termios structure. Updated BSPs to use dedicated input and output baud in termios structure. Updated tools to use dedicated input and output baud in termios structure. Updated termios testsuites to use dedicated input and output baud in termios structure. Close #2897. | ||||
* | m68k/mcf5225x/*/mc525x5-testsuite.tcfg: Add cdtest | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mcf52235/*/mc52235-testsuite.tcfg: Add cdtest | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mcf5225x/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mrm332/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | m68k/mcf52235/*.tcfg: Add fsjffs2gc01 to excluded tests | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
* | powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset | Joel Sherrill | 2017-01-16 | 1 | -0/+2 |
* | Rename is_internal to always_set_to_false | Sebastian Huber | 2016-12-12 | 6 | -6/+6 |
| | | | | Update #2825. | ||||
* | testsuite: Add test states to the testsuit configuration files. | Chris Johns | 2016-12-07 | 6 | -49/+49 |
| | | | | | | | | | | | | | | | | Change the testsuite configuration files to hold state information about a test. The states are: exclude - Do not build the test expected-fail - The test is expected to fail indeterminate - The test may pass or may fail A message is printed just after the test's BEGIN message to indicate there is a special state for the test. No state message means the test is expected to pass. This support requires tests are correctly written to the use standard support to begin and end a test. | ||||
* | m68k/mrm332/make/custom/mrm332-testsuite.tcfg: Add dl05 | Joel Sherrill | 2016-11-03 | 1 | -0/+1 |
* | m68k/mcf5225x/make/custom/mcf5225x-testsuite.tcfg: Add dl05 | Joel Sherrill | 2016-11-03 | 1 | -0/+1 |
* | m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg: Add dl05 | Joel Sherrill | 2016-11-03 | 1 | -0/+1 |
* | mcf5206elite/make/custom/mcf5206elite-testsuite.tcfg: Add dl05 | Joel Sherrill | 2016-11-03 | 1 | -0/+1 |
* | bsp/mvme147*: Fix linker issue | Sebastian Huber | 2016-09-23 | 2 | -6/+2 |
| | | | | | The GNU linker does not allow a nonconstant expression for a region length. | ||||
* | bsps/m68k: Add libatomic support to some bsp_specs | Sebastian Huber | 2016-09-23 | 3 | -3/+3 |
| | | | | Update #2695. | ||||
* | bsps/m68k: Fix linker command file | Sebastian Huber | 2016-09-23 | 1 | -1/+1 |
| | | | | Prevent garbage collection of interrupt vector table. | ||||
* | libchip: Simplify RTC driver | Sebastian Huber | 2016-07-04 | 1 | -2/+0 |
* | bsp/mvme162: Include missing <rtems/bspIo.h> | Sebastian Huber | 2016-06-28 | 1 | -0/+1 |
* | libnetworking: Import current <arpa/inet.h> | Christian Mauderer | 2016-06-28 | 2 | -2/+0 |
| | | | | | | | | | | Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>. Clean up problems with htonl(). These functions are defined in <arpa/inet.h>. This lead to some problems because they are defined in <rtems/endian.h> too. Add NTOHL, ... to <rtems/rtems_bsdnet_internal.h>. | ||||
* | mvme147s/shmsupp/mpisr.c: Fix warnings and clean up | Joel Sherrill | 2016-06-16 | 1 | -12/+10 |
* | mvme147s/shmsupp/getcfg.c: Fix warning | Joel Sherrill | 2016-06-16 | 1 | -1/+1 |
* | score: Rename _ISR_Disable() and _ISR_Enable() | Sebastian Huber | 2016-05-20 | 2 | -10/+10 |
| | | | | | | | | | Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable() into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant(). This is a preparation to remove the Giant lock. Update #2555. | ||||
* | m68k/uC5282/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -2/+0 |
* | m68k/mvme167/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | m68k/mvme162/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | m68k/mvme147s/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | m68k/mvme147/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | m68k/mvme147/console/console.c: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -0/+1 |
* | m68k/mrm332/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
* | m68k/mcf5329/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -2/+0 |
* | m68k/mcf5235/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -2/+0 |
* | m68k/mcf5225x/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -2/+0 |
* | m68k/mcf52235/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -2/+0 |
* | m68k/mcf5206elite/include/bsp.h: Do not include <rtems/iosupp.h> | Joel Sherrill | 2016-03-30 | 1 | -1/+0 |
