* consolex/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reworked.
* Makefile.am: Cosmetics.
* Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Misc cleanups and fixes.
* i2c/Makefile.am: Misc cleanups and fixes.
* nvram/Makefile.am: Misc cleanups and fixes.
* tod/Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Remove all: $(ARCH)..
* i2c/Makefile.am: Remove all: $(ARCH)..
* nvram/Makefile.am: Remove all: $(ARCH)..
* startup/Makefile.am: Remove all: $(ARCH)..
* tod/Makefile.am: Remove all: $(ARCH)..
* wrapup/Makefile.am: Remove all: $(ARCH).
Remove bogus wildcard from CPU_PIECES..
* configure.ac: Remove shared/gdbstub/Makefile.
* Makefile.am: merge-in gdbstub/Makefile.am.
Add stray files bspspuriousinit.c, m68000spurious.c.
* gdbstub/Makefile.am: Remove.
* startup/Makefile.am: Remove S_FILES.
* i2c/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
Add mvme/mvme16x_hw.h.
* fatal/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* consolex/Makefile.am: Add preinstallation dirstamp support.
* tools/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Cosmetics.
* spurious/Makefile.am: Cosmetics.
* fatal/Makefile.am: Remove all-local: $(ARCH).
* consolex/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* spurious/Makefile.am: Remove all-local: $(ARCH).
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
PR 503/bsps
* clock/ckinit.c, include/bsp.h, startup/efi68k_tcp.c, timer/timer.c:
Do not include DP8570A.h from bsp.h but still install it. This avoids
polluting the namespace.
* include/bsp.h: Replace stringification madness to pick up bare.h
(Doesn't work with gcc >= 3.3) with a somewhat cleaner madness.
* Makefile.am: Correct path to mvme16x_hw.h.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
PR 483/bsps
* startup/bspstart.c, startup/start_c.c: Spurious interrupt handlers
cannot be installed until RTEMS has initialized the vector table.
PR 483/bsps
* start/start.c, startup/bspstart.c: Spurious interrupt handlers cannot
* console/conscfg.c, include/bsp.h, startup/bspstart.c,
startup/spurious_assistant.c: URL for license changed.
* bspspuriousinit.c, m68000spurious.c, m68kpretaskinghook.c, setvec.c,
start.S, mvme/mvme16x_hw.h: URL for license changed.
startup/bspclean.c, startup/bspstart.c, timer/timer.c: URL for
license changed.
* clock/ckinit.c, console/console-recording.c, console/console.c,
fatal/bspfatal.c, include/bsp.h, include/coverhd.h, include/fatal.h,
include/page_table.h, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c, timer/timerisr.S: URL for license
changed.
* clock/ckinit.c, console/console.c, consolex/cTest.c,
consolex/consolex.c, consolex/consolex.h, include/bsp.h,
include/coverhd.h, include/tod.h, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c,
timer/timerisr.S, tod/tod.c: URL for license changed.
* include/bsp.h, include/coverhd.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspstart.c, startup/linkcmds: URL for license changed.
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
timer/timer.c: URL for license changed.
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
changed.
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
* README, console/console.c, i2c/i2c.c, i2c/i2cdrv.c, include/bsp.h,
include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h,
nvram/nvram.c, start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/gdbinit, startup/init5206e.c, startup/linkcmds,
startup/linkcmds.flash, tod/ds1307.c, tod/todcfg.c, tools/runtest:
* clock/ckinit.c, startup/bspstart.c, timer/timer.c, timer/timerisr.S:
