* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, start/start.c: Removed warnings.
* console/console.c, start/start.c, startup/efi68k_wd.c:
* startup/m68k-stub.c: Removed typos.
* console/conscfg.c, startup/bspstart.c: Removed warnings.
* startup/m68k-stub.c: Removed warnings.
* network/network.c, startup/bspclean.c: Removed warnings.
* startup/page_table.c: Removed warnings.
* m68k-stub.c: Corrected typos.
* m68k-stub.c: Fixed warnings about multi-line strings in asm.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS.
* Makefile.am: ACLOCAL_AMFLAGS = -I ../../../../../../aclocal.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* fatal/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* i2c/Makefile.am: Use .$(OBJEXT) instead of .o.
* nvram/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Pick up rest of Ralf'f changes and use
cp not make-rel since there is no point in this case.
* start/debugreset.S: Rights were not assigned.
* start/reset.S: Add ifdef to avoid core dump until Chris can
track it down.
* start/cpuboot.c: Moved to startup.
* startup/Makefile.am: Account for above.
* startup/Makefile.am: Remove -DGDB_MONITOR_ACTIVE (Not used
anywhere).
Add ODS60302_DEBUG conditional.
* include/bsp.h: Fix broken bsp_cat macros (Not compliant to gcc31).
* configure.ac: Add --enable-ods60302-debug.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* Makefile.am: Add transform and bsptools_bindir hacks.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit
linkcmds.flash.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom
linkcmds.bootp.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* m68k-stub.c: Eliminated multi-line asm statements for gcc 3.x.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory.
* configure.ac: Modified to reflect above.
* startup/Makefile.am: Compile the m68k gdb stub and glue.
