.s files to .S in conformance with GNU conventaons. This is a
it work.
<jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me
know what was wrong and I supplied the code. :)
If you're getting close to a new snaphot, here's something that
might be useful to add to the BSP README notes for systems with
networking.
Here's a small patch I forgot about from earlier in the week that removes
the hack fix Geoffroy had to use to get his BSP to work properly.
The termios osend() fix took care of this.
libchip, libio, and termios efforts.
and eliminate warnings.
Geoffroy Montel <g_montel@yahoo.com>.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
add support for changing the baudrate.
by newlib.
component.
the CPU family name constants.
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
Here's another small patch. The changes to socket.h are to provide
some definitions that UNIX BSD socket programmers expect. The
memcpy.c contains a memcpy routine optimized for the CPU32+. When I
run the ttcp benchmark with this routine I get host->68360 transfers
around 165 kbytes/sec (about a 25% improvement) and 68360->host
transfers of around 290 kbytes/sec (about a 50% improvement).
While trying to work through this problem I decided that the
build-time selection of the console I/O operation (polling or
interrupt) was too clumsy. Here's a patch that allows run-time
(actually init-time) selection of the console I/O mode.
It also shows the need for another `flags' or `options' field in
the rtems_driver_address_table structure...
"gmake debug".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
for the network driver attach entry point.
