* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* Makefile.am: Pick up ../mvme167/network/network.c.
* configure.ac: Remove RTEMS_CHECK_MULTIPROCESSING.
Remove AM_CONDITIONAL(HAS_MP).
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Distribute start/startfor340only.S.
* Makefile.am: Don't include subdirs.am.
* start/reset.S: Remove cat(). Add EXPAND(). Make EXCEPTION_HANDLER
ANSI-C compliant.
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am
start/Makefile.am, startup/Makefile.am, timer/Makefile.am
wrapup/Makefile.am.
Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* Makefile.am: Reflect having changed libcpu/m68k/mcf5206/console.rel
to libcpu/m68k/mcf5206/mcfuart.rel
* Makefile.am: Merge-in console/Makefile.am, i2c/Makefile.am,
nvram/Makefile.am, startup/Makefile.am, tod/Makefile.am,
wrapup/Makefile.am.
* console/Makefile.am, i2c/Makefile.am, nvram/Makefile.am,
startup/Makefile.am, tod/Makefile.am, wrapup/Makefile.am:
Remove.
* Makefile.am: Fix typo.
spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
Remove.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Remove.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
fatal/Makefile.am, network/Makefile.am, startup/Makefile.am,
* clock/Makefile.am, console/Makefile.am, fatal/Makefile.am,
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Remove.
* console/console-recording.c: Remove (rename to console-recording.h).
* console/console-recording.h: New.
PR 562/bsps
* Makefile.am: Remove references to m68k-gdbstub.c,
rtems-gdbstub-glue.c.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am.
Use automake-compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
Remove.
* README: Remove references to consolex.
tod/Makefile.am.
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove.
PR 563/bsps
* consolex/consolex.c, consolex/consolex.h, consolex/cTest.c,
consolex/Makefile.am, consolex/README:
Remove (Abandoned).
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
compilation rules.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
wrapup/Makefile.am.
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* consolex/Makefile.am: Add PREINSTALL_DIRS.
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* startup/Makefile.am: Remove non-existing files setvec.c,
bspclean.c, exit.c from EXTRA_DIST.
* timer/Makefile.am: Remove non-existing file timer.c from EXTRA_DIST.
* Makefile.am: Remove non-existing times from EXTRA_DIST.
* start/Makefile.am: Remove non-existing cpuboot.c from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* README: Fix minor typo.
* Makefile.am: Remove gdbstub/rtems-stub-glue.c (Non-existent)
* start/.cvsignore: Remove.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* consolex/Makefile.am: Ditto.
* configure.ac: Ditto.
