* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 7 | -1/+16 |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | ||||
* | Updates from Eric Norum. Changed CPU CFLAG and went to a common name | Joel Sherrill | 1998-01-06 | 1 | -150/+112 |
| | | | | for the network driver attach entry point. | ||||
* | Fixes from Eric Norum. C++ support added in previous version was broken: | Joel Sherrill | 1997-12-22 | 3 | -291/+272 |
| | | | | | | | | | | | | | | | | | | 1) In my haste to add C++ constructor/destructors to the 68360 linkcmds scripts I managed to break all existing 68360 programs. Linker scripts which actually produce a working executable are contained below. The problem was that the constructor/destructors weren't included before the etext symbol. On top of that Eric and I appear to have problems with attachments: 2) In deciphering the above problem I think I stumbled across the reason you've had with patches mailed from me. I noticed that the linkcmds (and linkcmds.bootp) scripts in the latest distribution have a control-M (carriage return) at the end of each line. Could you check the files below before installing them in the distribution and see that there aren't returns in the files? Maybe if I send everything as a tar attatchment things will work better. | ||||
* | Corrected prototypes for all termios console write driver entries to | Joel Sherrill | 1997-12-22 | 2 | -3/+3 |
| | | | | properly reflect the const on the buffer pointer being passed in. | ||||
* | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1997-12-20 | 11 | -22/+22 |
| | | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | ||||
* | Update from Eric Norum to include C++ support. | Joel Sherrill | 1997-12-20 | 3 | -239/+281 |
* | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1997-12-19 | 11 | -11/+11 |
| | | | | switch which lets the user specify a different linker script. | ||||
* | Modified a lot of files to take a first cut at supporting building from | Joel Sherrill | 1997-12-10 | 97 | -97/+388 |
| | | | | | any directory in the build tree. The only variable which must be set before the command "gmake" is invoked is RTEMS_BSP (e.g. RTEMS_BSP=erc32). | ||||
* | Corrected call to rtems_termios_open. | Joel Sherrill | 1997-11-30 | 1 | -1/+2 |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 1 | -11/+43 |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 |
* | Overhauled console driver to use termios and to simultaneously support | Joel Sherrill | 1997-10-23 | 3 | -149/+170 |
| | | | | both ports. | ||||
* | Control and Data addresses were swapped for port A. | Joel Sherrill | 1997-10-16 | 1 | -2/+2 |
* | Moved selection of console port to custom file. | Joel Sherrill | 1997-10-15 | 1 | -3/+0 |
* | New version of this file from Eric Norum. | Joel Sherrill | 1997-10-13 | 1 | -536/+534 |
* | Added search of libcpu and fpsp. | Joel Sherrill | 1997-10-09 | 1 | -0/+5 |
* | Modified to search RTEMS library before Newlib C library. | Joel Sherrill | 1997-10-08 | 11 | -11/+11 |
* | Update from Eric Norum: | Joel Sherrill | 1997-10-08 | 2 | -530/+540 |
| | | | | | Change label names so they can be seen from the debugger. Provide a start symbol -- gets rid of a loader warning message. | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 100 | -200/+200 |
* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 12 | -23/+23 |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | ||||
* | Merged changes from Eric Norum: | Joel Sherrill | 1997-09-18 | 3 | -16/+32 |
| | | | | | | | | | | | | | Enable 68360 watchdog. The watchdog control register is a `write-once' register, so the watchdog has to be enabled in the boot roms if it is to be used at all. To make the change transparent I added a default feed of the watchdog to the clock interrupt handler. This can be overridden if the application wants to handle the watchdog. The only difficulty with this change is that an application has to either include the clock driver or handle the watchdog explicitely. I don't think this is much of a problem since I am pretty sure that almost every application includes the clock driver. | ||||
* | eliminated potential for overfilling buffer on read | Joel Sherrill | 1997-09-15 | 10 | -10/+0 |
* | Fix from Eric Norum. Here is the comment: | Joel Sherrill | 1997-09-03 | 1 | -2/+2 |
| | | | | | | Enable SDMA operation during FREEZE. It seems that disabling SDMA during freeze makes the SMC channels work erratically. | ||||
* | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1997-08-28 | 11 | -319/+143 |
* | Modified to support the BSP family concept. | Joel Sherrill | 1997-08-27 | 1 | -2/+2 |
* | Modified to have correct address for vector table on multiple models. | Joel Sherrill | 1997-08-27 | 2 | -0/+10 |
* | Corrected to compile with egcs. | Joel Sherrill | 1997-08-26 | 2 | -5/+5 |
* | start no longer a global symbol per Eric Norum's request. | Joel Sherrill | 1997-08-22 | 2 | -2/+12 |
| | | | | | | | | | | Also, I ran across a nasty problem the first time I tried downloading and running an application compiled with the new snapshot. To make a very long story short, the `start' in ...../m68k/gen6860/start360/start360.s must not be global. The change is simple -- just remove the .globl start from start360.s. | ||||
* | Switched to new version of mc68681.h | Joel Sherrill | 1997-08-04 | 1 | -29/+29 |
* | moved mc68230.h from main include directory to motorola | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Corrected typo | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | Trying to support all models | Joel Sherrill | 1997-08-04 | 1 | -20/+4 |
* | Trying to support all models. | Joel Sherrill | 1997-08-04 | 1 | -0/+6 |
* | consolex built for all models. | Joel Sherrill | 1997-08-04 | 1 | -8/+4 |
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 8 | -9/+8 |
* | Correcting difference between mvme162lx and mvme162. All versions have | Joel Sherrill | 1997-08-04 | 1 | -0/+5 |
| | | | | four serial ports. | ||||
* | moved header files into the motorola and zilog subdirectories | Joel Sherrill | 1997-08-04 | 2 | -3/+5 |
* | Modified to reflect changes in mc68681.h header file. | Joel Sherrill | 1997-08-04 | 1 | -104/+200 |
* | Header files moved into zilog subdirectory. | Joel Sherrill | 1997-08-04 | 1 | -2/+2 |
* | Added consolex to wrapup | Joel Sherrill | 1997-08-01 | 1 | -0/+1 |
* | Corrected typo. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Made to work. | Joel Sherrill | 1997-08-01 | 1 | -1/+1 |
* | Removed warnings. | Joel Sherrill | 1997-08-01 | 1 | -2/+2 |
* | Katsutoshi Shibuya (shibuya@mxb.meshnet.or.jp)of BU-Denken Co., Ltd. | Joel Sherrill | 1997-08-01 | 7 | -7/+1139 |
| | | | | | | | (Sapporo, Japan) submitted the extended console driver for the MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines. This device driver supports four serial ports, cooked IO, and provides a portable base for Zilog 8530 based console drivers. | ||||
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 40 | -0/+6326 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. |
