path: root/c/src/lib/libbsp/m68k (follow)
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-063-2/+7
| | | | | * bspspuriousinit.c, m68000spurious.c: Include rtems/bspIo.h instead of bspIo.h.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-062-1/+5
| | | | * include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
| | | | | * startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h. * startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
* 2002-01-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-041-0/+6
| | | | | | | | | | | | * changes: Removed. * ChangeLog: New file. This must have slipped through in some automated changes. 2001-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-042-1/+6
| | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-0418-15/+30
* 2001-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-182-1/+23
| | | | | | | * configure.ac: Add RTEMS_BPSOPTS_*(CD2401_INT_LEVEL). Add RTEMS_BPSOPTS_*(CD2401_IO_MODE). Add RTEMS_BPSOPTS_*(CD2401_USE_TERMIOS). Add AC_DEFINE_UNQUOTED([mvme167]).
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-0332-112/+80
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-11-27 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-278-9/+59
| | | | | | | | This was tracked as PR39. * include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger, startup/linkcmds, startup/rom: Eliminated required definition of macros in the custom file for the BSP to compile. The ROM and ROM address and size settings are now linker script items.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-202-1/+5
| | | | | * include/bspopts.h.in: Automatically generated file that should not be in CVS.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-152-0/+13
| | | | | * configure.ac: Add RTEMS_BSPOPTS_*(USE_CONSOLE_A), add RTEMS_BSPOPTS_*(USE_CONSOLE_B).
* 2001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-302-1/+7
| | | | | | * start/start.S: Use __mcpu32__ instead of mcpu32 and change sense of conditional so cpu32 does not attempt to use 68000 style interrupt vectoring.
* 2001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-292-1/+5
| | | | * network/Makefile.am: Fix improper use of $(srcdir) in VPATH.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-293-0/+21
| | | | * .cvsignore, include/.cvsignore: Add more entries.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2610-0/+324
| | | | | | | | | | | | | | | * New BSP for MCF5206eLITE evaluation board BSP. * ChangeLog, README, bsp_specs, configure.ac, console/console.c, console/.cvsignore, i2c/i2c.c, i2c/i2cdrv.c, i2c/.cvsignore, include/bsp.h, include/bspopts.h.in, include/coverhd.h, include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h, include/.cvsignore, nvram/nvram.c, nvram/.cvsignore, start/start.S, start/.cvsignore, startup/bspclean.c, startup/bspstart.c, startup/gdbinit, startup/init5206e.c, startup/linkcmds, startup/linkcmds.flash, startup/.cvsignore, times, tod/ds1307.c, tod/todcfg.c, tod/.cvsignore, tools/.cvsignore, tools/configure.ac, tools/runtest, tools/changes, wrapup/.cvsignore, .cvsignore: New files.
* 2001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-262-0/+6
| | | | * acinclude.m4: Added mcf5206elite.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2638-0/+4377
* 2001-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-174-2/+39
| | | | | | | | * timer: New subdirectory. * timer/Makefile.am: New file. * timer/.cvsignore: New file. * Makefile.am: Modified to reflect above. * configure.ac: Ditto.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1217-0/+622
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1217-604/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1134-0/+119
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-0/+5
| | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-102-2/+40
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-2820-10/+50
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2720-10/+50
| | | | * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2710-10/+35
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-244-2/+12
| | | | * wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* 2001-09-14 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-212-6/+4
| | | | * startup/init68360.c: Modifications to make gcc 3.x happy.
* 2001-09-19 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-192-26/+9
| | | | * README: Bring it more in line with reality.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-192-1/+6
| | | | | * start/start.S: Reverse sense of conditional compilation so the code will compile for a cpu32.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-194-1/+13
| | | | * include/Makefile.am: Fixed typo.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-181-1/+1
| | | | * configure.in: Correct typo.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-186-22/+23
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * consolex/Makefile.am: Ditto. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1815-55/+63
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1830-59/+114
* 2001-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-184-3/+11
| | | | * include/Makefile.am: Fix typo in include_HEADERS.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1425-72/+97
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-259-1/+14
| | | | | | | * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Modified to include compile.am. * startup/bspstart.c: Removed include of <libcsupport.h>
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-2538-0/+2662
| | | | | | | | | | | | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-1128-14/+70
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-01-12 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-01-125-195/+112
| | | | | | | * README, clock/Makefile.am, clock/ckinit.c, clock/clock.c: Clock driver updated to use shell driver mechanism. * clock/ckinit.c: Removed. * clock/clock.c: New file.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-033-2/+9
| | | | | * start/start.S: Added space for vectors on CPU32 configuration. * startup/bspstart.c: Fixed typo.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-192-1/+8
| | | | | | * startup/linkcmds: Set _VBR to 0 to indicate that the vectors are in RAM not ROM. Thanks to Juan Zamorano <jzamora@fi.upm.es> for debugging this.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-192-1/+4
| | | | * Makefile.am: Removed unneeded blank line.
* 2000-12-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-142-3/+4
| | | | * network/network.c: Removed unused variable warnings.
* 2000-12-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-149-5/+1594
| | | | | | | | * Makefile.am, configure.in, include/Makefile.am, wrapup/Makefile.am: Updated to reflect addition of network driver by Franck Julien <FranckJ@cxr.fr>. * include/m302_int.h, network/.cvsignore, network/Makefile.am, network/network.c: New file.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-8/+45
| | | | | * README, sim68000.setup, clock/clockdrv.c: Modified to add support for timer as clock tick source. Compiles but untested.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-0/+12
| | | | | | * start/start.S, startup/bspstart.c: Not functional for CPU32 but hopefully will compile now and give a warning saying that the CPU32 variant needs work.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0932-16/+80
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0232-16/+80
