* | 2010-05-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-04 | 3 | -1/+8 |
| | | | | | * include/bsp.h: Add BSP_SMALL_MEMORY. * startup/linkcmds: Wildcard on .data so C++ links. | ||||
* | 2010-04-30 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-30 | 2 | -3/+6 |
| | | | | * include/bsp.h: Add BSP_SMALL_MEMORY. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 4 | -4/+10 |
| | | | | * startup/bsppredriverhook.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -3/+7 |
| | | | | * startup/m68k-stub.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 4 | -2/+10 |
| | | | | * timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 4 | -6/+13 |
| | | | | * startup/bspclean.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -4/+8 |
| | | | | * startup/bspclean.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -3/+6 |
| | | | | * startup/init5235.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -2/+7 |
| | | | | * console/leds.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -1/+7 |
| | | | | * console/m340uart.c, startup/init68340.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -4/+11 |
| | | | | * startup/init68360.c, timer/timer.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 3 | -8/+12 |
| | | | | * startup/bspclean.c, startup/bspstart.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -16/+5 |
| | | | | * startup/init5206e.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -19/+9 |
| | | | | * startup/init5272.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 2 | -112/+116 |
| | | | | * network/network.c: Remove warnings. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 3 | -64/+105 |
| | | | | | * network/network.c, startup/bspstart.c: Remove warnings. hwaddr handling changed to avoid use of unitialized variable. | ||||
* | 2010-04-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-27 | 4 | -65/+72 |
| | | | | | * network/network.c, startup/bspclean.c, startup/init5282.c: Remove warnings. | ||||
* | * startup/bspstart.c: Clean up some warnings. | Eric Norum | 2010-04-26 | 3 | -4/+10 |
| | | | | * network/network.c: Fix up full/half duplex printout and some warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -1/+6 |
| | | | | * network/network.c: Fix warning. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-26 | 2 | -4/+8 |
| | | | | * console/console.c: Fix prototypes. | ||||
* | 2010-04-18 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-18 | 3 | -0/+16 |
| | | | | * .cvsignore, include/.cvsignore: New files. | ||||
* | 2010-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-13 | 1 | -0/+4 |
| | | | | * console/console.c: Fix broken comment formatting. | ||||
* | Fix broken comment format. | Ralf Corsepius | 2010-04-13 | 1 | -2/+1 |
* | 2010-04-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-11 | 2 | -0/+6 |
| | | | | * console/debugio.c: Include <unistd.h>. | ||||
* | 2010-04-08 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-08 | 2 | -5/+9 |
| | | | | * start/start.S: Spacing. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 2 | -0/+6 |
| | | | | * acinclude.m4: Add mcf5225x BSP. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 2 | -0/+5 |
| | | | | * configure.ac: Add mcf5225x BSP. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 19 | -0/+2218 |
| | | | | | | | | * ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init, preinstall.am, clock/clock.c, console/console.c, console/debugio.c, include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5225x.c, startup/linkcmds, timer/timer.c: New files. | ||||
* | get desired clock rate for proper source | Thomas Doerfler | 2010-03-27 | 2 | -2/+8 |
* | 2010-03-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-04 | 2 | -1/+5 |
| | | | | | * README: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it. | ||||
* | combine all checks for missing MAC address | Thomas Doerfler | 2010-02-25 | 4 | -21/+24 |
| | | | | | enable FPU, if POSIX init task present explicitly disable all edge port interrupts | ||||
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 28 | -90/+154 |
* | get vital data from dBUG monitor for COBRA5475 board | Thomas Doerfler | 2009-12-14 | 4 | -2/+37 |
* | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-08 | 2 | -1/+7 |
| | | | | | * startup/init5206e.c: Make prototype of CopyDataClearBSSAndStart global. | ||||
* | 2009-12-08 Eric Norum <wenorum@lbl.gov> | Joel Sherrill | 2009-12-08 | 2 | -15/+13 |
| | | | | | PR 1479/bsps * fatal/bspfatal.c: Complete strcat conversion. | ||||
* | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-08 | 1 | -0/+1 |
| | | | | * include/i2c.h (i2c_transfer_done): Fix type mismatch. | ||||
* | (i2c_transfer_done): Fix type mismatch. | Ralf Corsepius | 2009-12-08 | 1 | -1/+1 |
* | 2009-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-08 | 1 | -0/+4 |
| | | | | * tod/ds1307.c (ds1307_set_time): Fix broken prototype. | ||||
* | (ds1307_set_time): Fix broken prototype. | Ralf Corsepius | 2009-12-08 | 1 | -1/+1 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 51 | -758/+758 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 23 | -27/+27 |
* | 2009-11-16 Alan Cudmore <alan.p.cudmore@nasa.gov> | Joel Sherrill | 2009-11-16 | 2 | -1/+6 |
| | | | | | * startup/init5235.c: Add volatile to prevent newer gcc versions from optimizing away. | ||||
* | 2009-11-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-03 | 2 | -1/+5 |
| | | | | * startup/init548x.c: Comment out junk from end of #endif. | ||||
* | Regenerate. | Ralf Corsepius | 2009-11-03 | 1 | -9/+1 |
* | 2009-11-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-03 | 7 | -7/+15 |
| | | | | | | | | | | * configure.ac: Add RTEMS_BSP_LINKCMDS. * make/custom/m5484FireEngine.cfg: Remove RTEMS_LINKCMDS. * make/custom/COBRA5475.cfg: Remove RTEMS_LINKCMDS. * make/custom/genmcf548x.inc: Remove LDFLAGS. * startup/linkcmds: Remove (Renamed into linkcmds). * startup/linkcmds.m5484FireEngine: New (Renamed from linkcmds). * Makefile.am: Rework linkcmds handling. | ||||
* | 2009-11-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-03 | 2 | -1/+4 |
| | | | | * startup/cfinit.c: Remove init_vbr (Unused). | ||||
| | | | | * startup/bspstart.c: Add missing prototype. | ||||
* | removed erronously added spi.c and spi.h | Thomas Doerfler | 2009-10-21 | 2 | -993/+0 |
* | add missing file | Thomas Doerfler | 2009-10-21 | 2 | -0/+993 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -3/+4 |
| | | | | * make/custom/uC5282.cfg: Remove RTEMS_BSP_FAMILY. |
