* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* i2c/Makefile.am: Use .$(OBJEXT) instead of .o.
* nvram/Makefile.am: Use .$(OBJEXT) instead of .o.
* start/Makefile.am: Pick up rest of Ralf'f changes and use
cp not make-rel since there is no point in this case.
* start/debugreset.S: Rights were not assigned.
* start/reset.S: Add ifdef to avoid core dump until Chris can
track it down.
* start/cpuboot.c: Moved to startup.
* startup/Makefile.am: Account for above.
* startup/Makefile.am: Remove -DGDB_MONITOR_ACTIVE (Not used
anywhere).
Add ODS60302_DEBUG conditional.
* include/bsp.h: Fix broken bsp_cat macros (Not compliant to gcc31).
* configure.ac: Add --enable-ods60302-debug.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* Makefile.am: Add transform and bsptools_bindir hacks.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
* startup/Makefile.am: Add bsplib_DATA = linkcmds rom debugger.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/Makefile.am: Add bsplib_DATA = linkcmds gdbinit
linkcmds.flash.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.prom
linkcmds.bootp.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* m68k-stub.c: Eliminated multi-line asm statements for gcc 3.x.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory.
* configure.ac: Modified to reflect above.
* startup/Makefile.am: Compile the m68k gdb stub and glue.
* gdbstub: New directory.
* Makefile.am: Modified to reflect above.
* Added m68k serial stub that is thread aware.
* ChangeLog, gdb_if.h, m68k-stub.c, Makefile.am: New files.
* ChangeLog: Corrected spacing.
* Per PR31, moved mvme16x_hw.h to shared/mvme.
* include/Makefile.am: Modified to reflect movement.
* include/mvme16x_hw.h: Moved to shared/mvme.
* startup/linkcmds.bootp, startup/linkcmds.prom: Per PR192 add
sections needed by gcc 3.1. linkcmds had already been fixed on
a gcc 3.1 clean up sweep.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* include/mvme16x_hw.h: Include <bsp.h> instead of targopts.h.
* configure.ac: Remove AC_EXEEXT (obsolete).
* fatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* consolex/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tod/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i2c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nvram/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
* Makefile.am: Adapt to automake-1.5.
