* console/console.c: char_ready() was never returning true so console
never processed input data
* console/console.c: added printk() support to default device
* include/bsp.h: Added #define for MOT_162BUG_VEC_ADDRESS
* startup/bspclean.c: Modified to use MOT_162BUG_VEC_ADDRESS
* startup/bspstart.c: Modified to use MOT_162BUG_VEC_ADDRESS
* make/custom/mvme162.cfg: Modified to use "RTEMS_CPU_MODEL=68lc040"
and "CPU_CFLAGS = -mcpu=68040 -msoft-float" so BSP will always
work with all board variations.
* README: Added notes on user required configuration changes and
information about board models and variants
* README.models: New file that contains a detailed list of MVME162
models and variants.
Signed-off-by: Vic Hoover <victor.hoover.ctr@navy.mil>
* make/custom/gen68360.cfg, make/custom/gen68360_040.cfg,
make/custom/pgh360.cfg: Simplify and clean up.
* network/network.c: Remove unused var "dptr".
PR 1917/bsps
* Makefile.am, console/conscfg.c: Modifications to add dynamic tables
for libchip serial drivers.
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
PR 1824/cpukit
* misc/interr.c, spurious/spinit.c: Return exit/shutdown status back to
boot_card(). boot_card() propagates this to bsp_cleanup() and returns
it to the assembly that started the application. bsp_cleanup()
prototype changed.
PR 1824/cpukit
* include/bsp.h, startup/bspclean.c: Return exit/shutdown status back
to boot_card(). boot_card() propagates this to bsp_cleanup() and
returns it to the assembly that started the application.
bsp_cleanup() prototype changed.
* shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR
after RTC replaced.
* Makefile.am: Remove reference to wrapup directory.
PR 1772/bsps
* console/sci.c: Use same default baud rate as monitor.
* startup/bspstart.c: Fix clock code on qemu. Also ensure UART is
initialized early for printk.
PR 1738/bsps
* clock/clock.c, include/bsp.h, network/network.c: system clock driver
programs the PIT w/o assuming the CPU clock frequency being a power
of two.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
Remove AC_ARG_VAR([RTEMS_BSP],[]).
Add RTEMS_ENV_RTEMSBSP.
* timer/timer.c: Include <bsp.h> before <rtems/btimer.h>.
PR 1738/bsps
* README, startup/bspstart.c, startup/linkcmds: Add support for dynamic
clock speed determination. This algorithm is described in the README
file. The output of the RTEMS Timing Tests was moved to TIMES to
signicantly shrink the README.
* TIMES: New file.
* include/bsp.h, startup/m68k-stub.c, startup/trace.c:
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c:
* startup/bspclean.c, startup/page_table.c:
* shmsupp/lock.c:
* startup/cfinit.c:
* include/bsp.h:
* include/bsp.h, shmsupp/lock.c, startup/bspclean.c:
* clock/clock.c, startup/bspstart.c, startup/init5282.c:
* include/bsp.h, include/mrm332.h, spurious/spinit.c:
* startup/init5235.c:
* startup/cfinit.c:
* include/bsp.h startup/init5206e.c:
* console/mc68ec.c:
* include/bsp.h, startup/init5272.c:
* startup/bspstart.c, startup/init5282.c:
* shared/gdbstub/m68k-stub.c:
* timer/timer.c: Include <rtems/btimer.h>.
* mcf5206elite/tools/runtest: Fix typo where license said
found in found in.
* start/start.S: Fix mismatched comment.
* startup/init68360.c: Fix type punning warning.
* network/network.c: Fix warning.
* spurious/spinit.c: Add include of bootcard.h to fix warning.
* console/console.c: Add BSP_poll_char.
* console/debugio.c: Add BSP_poll_char.
* console/console.c: Add BSP_poll_char. Reformat.
* startup/m68k-stub.c: PR 1539. Fix buffer overrun.
* README: Remove more ITRON references.
