* | Regenerate. | Ralf Corsepius | 2006-01-12 | 18 | -0/+72 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 18 | -36/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 18 | -18/+18 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 18 | -18/+0 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -283/+30 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 27 | -683/+82 |
* | New. | Ralf Corsepius | 2006-01-11 | 18 | -0/+1092 |
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -2/+6 |
| | | | | * network/network.c: Remove warnings. | ||||
* | Add another 'extended BSP' routine which returns reboot status register ↵ | Eric Norum | 2005-12-19 | 2 | -0/+42 |
| | | | | information | ||||
* | 2005-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-12 | 4 | -8/+8 |
| | | | | * bsp_specs: Remove %cpp. | ||||
* | 2005-11-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-12 | 3 | -7/+8 |
| | | | | | * bsp_specs: Remove %cpp. * console/console.c: Eliminate obsolete types. | ||||
* | Clean up UART2 pin setup. Protect pin setup code. | Eric Norum | 2005-11-11 | 3 | -2/+12 |
* | Add code to set up pin assignments. | Eric Norum | 2005-11-08 | 2 | -2/+21 |
* | Remove assignation to U.S. Government. | Eric Norum | 2005-11-07 | 2 | -2/+0 |
* | Assign copyright to OAR since all files descend from OAR's source. | Eric Norum | 2005-11-07 | 11 | -23/+81 |
* | Fixed formatting. | Joel Sherrill | 2005-11-07 | 1 | -3/+3 |
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+6 |
| | | | | | | * console/console.c: Eliminate unsigned32, unsigned8. * include/bsp.h: Eliminate unsigned32. * startup/bspstart.c: Eliminate unsigned32. | ||||
* | Eliminate unsigned32. | Ralf Corsepius | 2005-11-07 | 4 | -10/+10 |
* | Eliminate unsigned32, unsigned8. | Ralf Corsepius | 2005-11-07 | 1 | -3/+3 |
| | | | | | | * include/bsp.h: Eliminate unsigned32. * network/network.c: Several minor bug fixes. * startup/bspstart.c: Eliminate unsigned32. | ||||
* | Several minor bug fixes. | Ralf Corsepius | 2005-11-07 | 1 | -1/+6 |
* | Allow network to be locked at 100/Full. | Eric Norum | 2005-10-26 | 3 | -4/+25 |
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -94/+0 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -28/+94 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Silently return to bootstrap PROM. | Eric Norum | 2005-09-19 | 1 | -1/+0 |
* | Correct my email address. | Ralf Corsepius | 2005-09-19 | 1 | -8/+8 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+4 |
| | | | | * network/network.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 1 | -1/+1 |
* | Add bsp_reset bootrom call. | Eric Norum | 2005-09-16 | 4 | -8/+7 |
| | | | | Call bsp_reset from bsp_cleanup(). | ||||
* | New file. | Joel Sherrill | 2005-08-17 | 1 | -0/+9 |
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 2 | -0/+6 |
| | | | | * acinclude.m4: Add the av5282 BSP. | ||||
* | 2005-08-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-08-17 | 20 | -0/+3969 |
| | | | | | | | | | * .cvsignore, Makefile.am, README, bsp_specs, configure.ac, clock/clock.c, console/console.c, include/bsp.h, include/bspopts.h.in, include/coverhd.h, include/tm27.h, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5282.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files. | ||||
* | Add .gnu.linkonce.b | Eric Norum | 2005-07-24 | 2 | -1/+5 |
* | Add .gnu.linkonce.b.* relocation. | Eric Norum | 2005-07-24 | 1 | -0/+1 |
* | Enable CS1* and CS2* now that Arcturus bootstrap PROMs no longer take care ↵ | Eric Norum | 2005-07-06 | 2 | -0/+5 |
| | | | | of that for us. | ||||
* | Add description of external interrupt request assignments. | Eric Norum | 2005-06-30 | 1 | -0/+3 |
* | Reflect changes to network driver. | Eric Norum | 2005-06-29 | 1 | -1/+1 |
* | Drive LEDs with more useful information. | Eric Norum | 2005-06-29 | 1 | -0/+2 |
* | Add duplex negotation support. | Eric Norum | 2005-06-29 | 2 | -46/+99 |
* | Minor tweak to make it easier to insert some code to test realignment. | Eric Norum | 2005-06-22 | 1 | -2/+2 |
* | Clean up transmit buffer realignment. | Eric Norum | 2005-06-20 | 3 | -74/+84 |
| | | | | Many thanks to Mr. Kolja Waschk for identifying the problem. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 1 | -0/+4 |
| | | | | * include/.cvsignore: New file. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -0/+6 |
| | | | | * acinclude.m4: Added mcf5235. | ||||
* | 2005-06-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-06-17 | 20 | -0/+3885 |
| | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5235.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 30 | -30/+90 |
| | | | | * include/bsp.h: New header guard. | ||||
* | Fix typo. | Eric Norum | 2005-05-24 | 1 | -1/+1 |
* | Try to maintain compatability with everyone else's VBR changes. | Eric Norum | 2005-05-24 | 4 | -10/+6 |
* | 2005-05-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-20 | 2 | -1/+5 |
| | | | | * console/duart.c: Remove warning. | ||||
* | Followup fix to Joel's earlier _VBR changes. | Eric Norum | 2005-05-11 | 2 | -0/+9 |
