* | 2009-09-09 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-09 | 2 | -0/+46 |
| | | | | | | * startup/bspstart.c: Added dummy implementation of firmware syscalls for use with QEMU. Dummy handler is installed if no pre-existing firmware handler is found. | ||||
* | Try enabling the data cache. | Eric Norum | 2009-07-30 | 4 | -12/+12 |
* | PR 1420/bsps | Eric Norum | 2009-07-28 | 2 | -1/+14 |
| | | | | | | Turn on buffered writes to DRAM. As Device Errata SECF124 notes this may cause double writes, but that's not really a big problem and benchmarking tests have shown that buffered writes do gain some performance. | ||||
* | Add PR 1420. | Joel Sherrill | 2009-06-03 | 1 | -0/+1 |
* | As per Freescale chip errata, disable buffered writes. | Eric Norum | 2009-06-02 | 2 | -3/+19 |
* | Clean up mishaps arising from multiple folks trying to fix the same problem. | Eric Norum | 2009-03-05 | 1 | -58/+5 |
| | | | | This version matches the trunk. | ||||
* | 2009-03-02 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-03-02 | 2 | -5/+64 |
| | | | | | | PR 1375/bsps * clock/clock.c: Correct implementation of nanoseconds since last tick handler. | ||||
* | 2009-02-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-27 | 3 | -180/+7 |
| | | | | | * Makefile.am: Remove unnecessary copy of cpu_asm.S * console/Modif_cpu_asm.S: Removed. | ||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -17/+40 |
| | | | | | PR 1371/bsps * network/network.c: mvme167 network driver buggy. | ||||
* | 2009-02-17 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-17 | 2 | -4/+17 |
| | | | | | | PR 1370/bsps * console/console.c: mvme167 console driver BSP_output_char fails to convert \n -> \n\r | ||||
* | 2009-01-21 Frank Ueberschar <frank.ueberschar@dsa-volgmann.de> | Joel Sherrill | 2009-01-21 | 2 | -1/+11 |
| | | | | | | | | | | PR 1354/bsps * network/network.c: In some cases it can occur that an empty mbuf is put on the descriptor chain. (We found it especially then when transmitting fragmented IP Packets.) Since the actual buffer descriptor pointer will be incremented after every inserted mbuf (txBd = sc->txBdBase + sc->txBdHead;) even if m->m_len of the current mbuf was zero. This leads to the bug. | ||||
* | 2009-01-21 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2009-01-21 | 2 | -6/+10 |
| | | | | | PR 1358/bsps * clock/clock.c: Fix time-access bug in uc5282 BSP. | ||||
* | 2008-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-08 | 40 | -43/+120 |
| | | | | * bsp_specs: Backport from CVS-HEAD. | ||||
* | removed orphaned spi/mc68360_spidrv.c | Thomas Doerfler | 2008-10-21 | 2 | -627/+5 |
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 18 | -89/+43 |
| | | | | * timer/timer.c: Eliminate uses of old benchmark timer names. | ||||
* | 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 3 | -490/+5 |
| | | | | * start/startfor340only.S: Remove (unused). | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 8 | -4/+16 |
| | | | | * Makefile.am: Remove noinst_PROGRAMS (Unused). | ||||
* | Cosmetics. | Ralf Corsepius | 2008-09-24 | 1 | -1/+0 |
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 3 | -0/+15 |
| | | | | | PR 1322/bsps * include/bspopts.h.in: Remove. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 3 | -67/+0 |
* | corrected parameters inside i2c driver for done signalling | Thomas Doerfler | 2008-09-08 | 4 | -17/+28 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 5 | -12/+12 |
* | 2008-09-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-06 | 1 | -0/+4 |
| | | | | * startup/m68k-stub.c: Convert to "bool". | ||||
| | | | | * shared/gdbstub/m68k-stub.c: Convert to "bool". | ||||
| | | | | * misc/interr.c: Convert to "bool". | ||||
| | | | | * tod/todcfg.c: Convert to "bool". | ||||
| | | | | * spi/mc68360_spidrv.c: Convert to "bool". | ||||
* | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-05 | 18 | -301/+64 |
| | | | | | | | * clock/ckinit.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 2 | -9/+9 |
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+4 |
| | | | | * i2c/i2c.c, i2c/i2cdrv.c: Convert to "bool". | ||||
| | | | | * spi/m360_spi.c, timer/timer.c: Convert to "bool". | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 27 | -65/+66 |
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 1 | -0/+5 |
| | | | | | * console/console.c, fatal/bspfatal.c, include/fatal.h, timer/timer.c: Convert to "bool". | ||||
| | | | | * console/console.c, timer/timer.c: Convert to "bool". | ||||
| | | | | * include/bsp.h, console/console.c, timer/timer.c: Convert to "bool". | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 7 | -0/+28 |
| | | | | * timer/timer.c: Convert to "bool". | ||||
* | 2008-09-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-05 | 3 | -0/+12 |
* | 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-03 | 2 | -1/+6 |
| | | | | | PR 1304/bsps * Makefile.am: Add ../../shared/bsppredriverhook.c. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 24 | -154/+113 |
| | | | | | * timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 9 | -60/+42 |
| | | | | | * timer/timer.c, timer/timerisr.S: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 4 | -24/+15 |
| | | | | | * console/console.c, include/m340timer.h, timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 2 | -4/+9 |
| | | | | | * timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 6 | -21/+31 |
| | | | | | * timer/timer.c, timer/timerisr.S: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 22 | -61/+116 |
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 4 | -12/+17 |
| | | | | | * console/console.c, include/m340timer.h, timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 3 | -9/+14 |
* | 2008-08-30 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-30 | 2 | -0/+8 |
| | | | | * acinclude.m4: Add mcf52235 and mcf5329. Regenerate. | ||||
* | various changes to gen83xx BSP and others | Thomas Doerfler | 2008-08-26 | 1 | -4/+0 |
