PR 1354/bsps
* network/network.c: In some cases it can occur that an empty mbuf is
put on the descriptor chain. (We found it especially then when
transmitting fragmented IP Packets.) Since the actual buffer
descriptor pointer will be incremented after every inserted mbuf
(txBd = sc->txBdBase + sc->txBdHead;) even if m->m_len of the current
mbuf was zero. This leads to the bug.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* startup/linkcmds, startup/linkcmds_ROM: Add wildcard to
gcc_except_table section so programs compiled with gcc 4.3.x can
link.
* startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Add
wildcard to gcc_except_table section so programs compiled with gcc
4.3.x can link.
* startup/linkcmds, startup/linkcmds.flash: Add wildcard to
link.
* startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add
4.3.x can link.
* clock/ckinit.c, console/duart.c, timer/timer.c: Reflect changes
to rtems/motorola/*.h.
* network/network.c: Fix LED configuration to match uCDIMM.
* clock/clock.c: Add nanoseconds since tick support.
* runtest: Add capture to list of interative tests to skip in batch
mode.
* console/leds.c, console/mc68ec.c: Rename delay to rtems_bsp_delay to
avoid conflicts in application space.
* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am,
dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am,
dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c,
dmv152/include/.cvsignore, dmv152/include/bsp.h,
dmv152/include/coverhd.h, dmv152/include/tm27.h,
dmv152/spurious/spinit.c, dmv152/startup/bspclean.c,
dmv152/startup/bspstart.c, dmv152/startup/linkcmds,
dmv152/startup/vmeintr.c, dmv152/timer/timer.c,
dmv152/timer/timerisr.S: Removed.
* startup/linkcmds: Handle .data.* sections
* Makefile.am: Minor rework to shrink minimum size to <48K.
* mcf5206elite/tools/runtest: Do not run pppd.exe from batch mode
script.
* bsp_specs: Remove qrtems_debug.
* bsp_specs: Remove lib: (Now supposed to be in GCC).
* Makefile.am: Add dummy printk support so all tests link.
* Makefile.am, configure.ac: Add dummy printk support so all tests
link.
* include/bsp.h: Remove redundant prototypes.
* clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
timer/timer.c: Correct license URL and/or fix mistake in copyright
notice. Both of these mistakes appear to be from code submitted after
these changes were made previously.
* include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Correct license URL and/or fix mistake in
copyright notice. Both of these mistakes appear to be from code
submitted after these changes were made previously.
* console/console-io.c, include/bsp.h, start/start.S,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c: Correct
license URL and/or fix mistake in copyright notice. Both of these
mistakes appear to be from code submitted after these changes were
made previously.
* startup/bspstart.c: Remove assignments of
Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default
value in boot_card.c
PR 1227/bsps
* include/bsp.h: Remove MAX_LONG_TEST_DURATION and
MAX_SHORT_TEST_DURATION. They are obsolete and unused.
* Makefile.am: Use MKDIR_P instead of mkdir_p.
* network/network.c: Use ioctl_command_t as arg in ioctl-functions.
the special handling of a 'FPGA interrupt' [this FPGA is *not*
present on the uC5282 module but is externally connected to
IRQ1 on Eric Norum's particular 'motherboard'] is only
activated when connecting to the special vectors > 192.
The change allows us ordinary users [:-)] to use IRQ1
normally, simply by connecting an ISR to vector 64+1...
Also, BSP_enable_irq_at_pic(), BSP_disable_irq_at_pic(),
BSP_irq_is_enabled_at_pic() were introduced (compat. with
some PPC BSPs).
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* include/m68349.inc, start/start.S, startup/dumpanic.c:
Convert to utf-8.
* console/console.c, console/sci.c, console/sci.h, spurious/spinit.c,
startup/bspclean.c, startup/start_c.c: Convert C++ style comments to
C style.
* console/console.c, startup/init5235.c: Convert C++ style comments to
C style.
* startup/init5282.c: Convert C++ style comments to C style.
* Makefile.am, README, startup/init5235.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235
eval boards to either load and run from ram using the dBug moniter as
the boot deviced (Board setup as shipped from the factory), or it
allows the user to Boot his code from flash he loads onto the eval
board. The code changes between the two are based on the selected
linker script using a variable in the script. The options to the
linker are used to override the default linker script and select
which options to configure at boot either from flash, or from ram:
-qnolinkcmds -T linkcmdsflash
If no options are given the standard linker sript assumes dBug was
used to set up the board and the user is going to load his program
to RAM.
